Let's Talk Cyclecars
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Dec 4, 2007.
  1. 1biggun
    1biggun
    This was on display at private residence car show in Cookeville WI Yesterday.
    Indian engine, 3 speed, chain drive to one wheel. Throttle on the left clutch on the right . Band brake on the rh rear. 20260616_095654.jpg
    mohr hp, Outback, porkshop and 5 others like this.
  2. fredvv44
    fredvv44
    Board track racer for sure. Only has tires on the off side!!
  3. banjeaux bob
    banjeaux bob
    from alaska
    Just like building an hot rod used to be about going to the junkyard and finding the parts and modifying them to build a vehicle. Now, you just pick up the phone and give them your credit card number.
    fredvv44 and Ned Ludd like this.
  4. banjeaux bob
    banjeaux bob
    from alaska
    Duncan Pittaway runs his steam car in the London to Brighton event. He also built the Hornet as well as the huge Fiat Mephisteles.
  5. banjeaux bob
    banjeaux bob
    from alaska
    I eblackdesign_1_11.jpg think this is one of Eric B's designs.
    porkshop, Okie Pete, fredvv44 and 2 others like this.
  6. fredvv44
    fredvv44
    Wow, love that!!
  7. banjeaux bob
    banjeaux bob
    from alaska
  8. banjeaux bob
    banjeaux bob
    from alaska
  9. WZ JUNK
    WZ JUNK
    from Neosho, MO
    IMG_4089.jpeg This is from about a month ago. I am pretty close to the first test drive now and then it will be body work and paint. The next big fabrication will be the hood and the hood sides. Harley engine, 700r transmission.
    Okie Pete, Ziggster, motoklas and 2 others like this.
  10. fredvv44
    fredvv44
    How are you dealing with the torque thumps from the engine? They tear a gear box apart.
    motoklas and Ned Ludd like this.
  11. Ned Ludd
    Ned Ludd
    A non-lockup torque converter will help?
    motoklas likes this.
  12. timberwolf01
    timberwolf01
  13. Ziggster
    Ziggster
  14. Ziggster
    Ziggster
    Okie Pete, porkshop and Outback like this.
  15. fredvv44
    fredvv44
    When I first saw the facebook video I thought it had to be an AI video.
    Ziggster, porkshop and Outback like this.
  16. Outback
    Outback
    from NE Vic, Oz
    Okie Pete, Ned Ludd and porkshop like this.
  17. Stuart Rose
    Stuart Rose
    It would be great to hear from any other Austin 7 compe***ors anywhere in the world here are a couple of photos of my cars Screen Shot 2021-02-23 at 23.02.21.png 503906145_9884081928378225_1004726693282598144_n.jpg
    Outback, Okie Pete, motoklas and 3 others like this.
  18. Ziggster
    Ziggster
  19. fredvv44
    fredvv44
    The Gratfon appears to have chain drive to the rear wheels via short chains from some device under the seat. I cannot see a driveshaft so I wonder how power gets from the engine upfront to the rear.
    Okie Pete and porkshop like this.
  20. Ziggster
    Ziggster
    Have a look at this vid at about the 2 minute mark. In another vid he mentions it has 3 forward speeds and no reverse.
    Okie Pete, motoklas and porkshop like this.
  21. fredvv44
    fredvv44
    Thanks, what a great video. He needs to have a key in that rear sprocket rather than just clamping it up tight. I still couldn't see the gearbox so I ***ume it it a motorcycle box with clutch.
    Okie Pete likes this.
  22. Ziggster
    Ziggster
    I suspect it’s some type of GN gearbox.
    Okie Pete, mohr hp, Ned Ludd and 2 others like this.
  23. fredvv44
    fredvv44
    I haven't read the book the Grafton was built from so I don't know what it suggests. A chain gang setup requites a bevel box of some sort and lots of fiddly bits to make it work. A bike box with clutch would be so simple to do. It does look like a chain is coming from something forward toward the engine with one chain driving the jack shaft and a chain to each rear wheel. It was the jack shaft sprocket that failed in your video.
    Along this line of thought I've always wondered hoe the Bedalia tensioned the drive belts to make it go. There appears to be a jack shaft for the front pulleys but then how is that connected to the engine without slacking a belt there?
  24. Ziggster
    Ziggster
    Google AI says this.
  25. You guys need to check out Oak Swamp on YouTube. He built an Austin/Crosley thing with chain drive.
  26. fredvv44
    fredvv44
    Ok Zig. Just what I guessed.
    Oak Swamp is quite a nice site. Looks like he followed the lead of ****** Mary with that build. I would think a Crosley engine would be really rare across the pond.
    Stueeee, porkshop and Ziggster like this.
  27. Ned Ludd
    Ned Ludd
    Crosley or Crossley?
    Indeed Crosley:
  28. fredvv44
    fredvv44
    Interesting build but I couldn't listen to him blabber on for 20 or 30 minutes,
    porkshop likes this.
  29. Ziggster
    Ziggster
    I watched that vid, but agree that he’s all over the place. Watched a few more in the series as I’m interested in his rear axle setup, but got tired of all the other content. It’s too bad as he has got talent and does really interesting stuff.
  30. Ziggster
    Ziggster
    Anyone know what this is?
    mohr hp, motoklas, porkshop and 2 others like this.
