Let's Talk Cyclecars
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Dec 4, 2007.
  1. 64 DODGE 440
    64 DODGE 440
    from so cal
    If sitting and idling was a problem, wouldn't all air cooled engine motorcycles have the same problem? Seems like it has worked on lots of different bikes from the old longitudinal Henderson fours up to modern Harleys and a whole lot of stuff in between.
  2. I have a friend that after he got out of the service in the early 70's built a VW bike. He was a former Navy Seal and full of pis and vinegar. He used a 1952 Indian Warrior TT frame, and a BMW transmission. He machined all the parts to mate the VW engine to the BMW transmission. He bolted a Honda front end on and used a Harley gas tank. The rear end was BMW, but years later was changed to a Honda Goldwing. When he finished the bike to did the usual shake down run and then sent the bike to Ireland. He and a group started at the top of Ireland and over a year made there way South to the tip of South Africa. The only part of the trip they didn't ride there bikes was when they by ship crossed the English Channel. To this day he can still name every town or village for thousands of miles down the Western coast of places like France, Spain, Portugal, and all the country's of Africa. He has some interesting stories about the people and places he visited.
    Today he has over 500,000 miles on the bike. Pappy was in his twenty's when he built the bike and today he's an old man like myself. For years I've been trying to get him to write the story about his grand adventure. As I write this he's out in his sail boat somewhere around Belize. He should be back in the Spring.
  3. farna
    farna
    The point is that those engines were DESIGNED with sitting and idling with no air flow in mind, so they should idle for long periods without problems. The VW flat four was designed with a fan to continually create air flow around the cylinders even at idle.
    I have to agree though -- with the engine sitting out in the open it SHOULD be okay at idle with no load. Covering it with body work is probably the only reason it needed forced air even at idle. Plus it would be doing a good bit of work at low speeds pulling a heavy load and would overheat then without forced air flow.
  4. 64 DODGE 440
    64 DODGE 440
    from so cal
    Out in the open works, Johnny Sweet's post shows how well it can. I've known several people who had VW conversions in BMW bikes, (had a stock '55 R69 myself) and never heard of any problems with heat.
  5. model.A.keith
    model.A.keith
  6. model.A.keith
    model.A.keith
  7. model.A.keith
    model.A.keith
  8. model.A.keith
    model.A.keith
  9. model.A.keith
    model.A.keith
  10. model.A.keith
    model.A.keith
  11. model.A.keith
    model.A.keith
  12. Ned Ludd
    Ned Ludd
    I love that diversely-***embled quality; the mismatched gauges, the various switchgear; and especially the way everything hangs together despite the miscellaneousness.
  13. fnqvmuch
    fnqvmuch
    this is Citroen's 1015 cc GS motor/transaxle/inboard disc unit as raced in MEP X27s; no sign of the fan / shrouds (or trick suspension ...)
  14. Gofannon
    Gofannon
    So how did the midget guys keep their VW motors cool? They were putting out some good power. What were they using for a trans? In/out box, or powerglide maybe?
  15. Ned Ludd
    Ned Ludd
    Cool:
    It seems that the design was developed around a Panhard flat-twin and the GS engine subs***uted later, which explains why there seems to be no sign of any part of the hydropneumatic suspension.
  16. noboD
    noboD
  17. Gofannon
    Gofannon
  18. Gofannon
    Gofannon
    I just did a google search on fabric bodies, of course the best info came up right here on the HAMB! The Minerva at the end of the post has a very effective looking body.
    http://www.jalopyjournal.com/forum/showthread.php?t=183868&highlight=fabric+bodies
    Which led to:
    http://www.polyfiber.com/
    It looks like a simple construction method, and Poly-Fiber seems easy to use. I'm a body man myself and could construct something out of aluminum, however the fabric bodies look like a simpler and faster way to go, paticularly for those less adept at body work. It also fits in much better with the cyclecar era.
  19. Gofannon
    Gofannon
  20. revkev6
    revkev6
    from ma
  21. 64 DODGE 440
    64 DODGE 440
    from so cal
    I've done a lot of aircraft fabric work, (A&P Mechanic by trade, vintage aircraft restoration by choice). The Poly Fiber stuff is a joy to work with and if you follow the directions in their manual, it's pretty hard to screw it up. The main thing you need for the work is patience, a good iron for the shrinking that will hold the proper temperatures and a good thermometer to set the temperatures. Fun stuff to work with and magic how the stuff smooths out as you work with it.
    Planning on building a Morgan style trike with a fabric body in a year or so.
  22. Gofannon
    Gofannon
    So, apart from the fact that it is a VW, this would be a HAMB friendly cyclecar engine??:eek:
  23. model.A.keith
    model.A.keith
  24. model.A.keith
    model.A.keith
  25. model.A.keith
    model.A.keith
  26. model.A.keith
    model.A.keith
  27. model.A.keith
    model.A.keith
  28. model.A.keith
    model.A.keith
  29. model.A.keith
    model.A.keith
  30. model.A.keith
    model.A.keith
