Let's Talk Cyclecars
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Dec 4, 2007.
  1. SanctaRosa
    SanctaRosa
    Voisin Laboratoire
  2. SanctaRosa
    SanctaRosa
    Voisin Laboratoire
  3. UKAde
    UKAde
    from Oxford UK
    http://www.driving-fun.com/forum/viewtopic.php?f=19&t=1336
    There are some good images of the voisin with it's clothes off , this car is great there seem to be. Number of recreations good and bad ,which makes research problematic it's easier doing the jappic as there are less details available
    The last recreation I helped with was the deemster we only had four of five pictures to work from
  4. gnichols
    gnichols
    from Tampa, FL
    Now that's a real cutie-pie. Gary
  5. av8
    av8
    Yes! That's the type of info I've been after. It's going to be difficult to stay on track with the three-wheeler project now.:D
    Thanks much . . .
    Mike
  6. Ned Ludd
    Ned Ludd
    Indeed. The Reliant Robin springs (or rather, er, tumbles) to mind.
    Do you have the formula for RAC horsepower? Bore² x number of cylinders / 1613.
    I wonder how much influence taxable horsepower ratings actually had, though, as the tendency was for thoroughly undersquare proportions even in places where such taxation did not apply. The lead given by Pomeroy's late-Edwardian "high speed" engines was taken up by manufacturers outside the UK, but these generally persisted with long strokes. One might say that the advantages of lightweight pistons, compact combustion chambers, and a short, rigid block outweighed considerations of mean piston speed when "high speed" meant something between 2500 and 3000 rpm. It is remarkable then that Delage returned to an emphatically undersquare engine (55.8mm x 76mm) in 1926 for the 15 S8 racing car, which peaked at 8000rpm, after their ever-so-slightly oversquare V12 of 1923.
    Of course, mean piston speed at any given rate of rpm is a function not of the bore:stroke ratio but of stroke pure and simple. That is why very underquare engines can achieve silly crank speeds as long as they are small engines. The above Delage 1½-litre straight-8 has the same stroke as a Chevy 283 of over three times the capacity (or rev-happy 302) but probably less than 20% of the piston m***.
    Had it been a road-going engine the Delage would have carried a RAC rating of 15½hp, which was not extravagant, yet it was a perfectly rational design of engine. Its actual output was nearer 180bhp.
  7. banjeaux bob
    banjeaux bob
    from alaska
    Morgan F Super / Achille pic
  8. banjeaux bob
    banjeaux bob
    from alaska
    Morgan Aero / Achille pic
  9. banjeaux bob
    banjeaux bob
    from alaska
    Sanford GS / Achille pic
  10. banjeaux bob
    banjeaux bob
    from alaska
    FOUR wheeled Sanford.
  11. fur biscuit
    fur biscuit
    saw this fine little green machine cruising through the 'hood in Sausalito!
  12. banjeaux bob
    banjeaux bob
    from alaska
    GN Gnat. Graham Little pic
  13. banjeaux bob
    banjeaux bob
    from alaska
    GN Spider. G.L. pic
  14. banjeaux bob
    banjeaux bob
    from alaska
    Supercharged MG. G.L. pic
  15. morac41
    morac41
    Hi Bob...Is there any other photos of the GN Gnat...What are the spec's of this car....
  16. banjeaux bob
    banjeaux bob
    from alaska
    Ben Marchant's 1900 cc BAC engined Austin Seven special. G.L. pics
  17. banjeaux bob
    banjeaux bob
    from alaska
    Amilcar . G.L. pic
  18. banjeaux bob
    banjeaux bob
    from alaska
    Vernon Derby . G.L. pics
  19. banjeaux bob
    banjeaux bob
    from alaska
    Amilcar. G.L. pics
  20. banjeaux bob
    banjeaux bob
    from alaska
    Frazer Nash. G.L. pic
  21. banjeaux bob
    banjeaux bob
    from alaska
    Amilcar. G.L. pics
  22. banjeaux bob
    banjeaux bob
    from alaska
    Morgan Aero. G.L. pics
  23. banjeaux bob
    banjeaux bob
    from alaska
    Suspension detail. G.L. pic
  24. banjeaux bob
    banjeaux bob
    from alaska
    Here are some more GNat images.Mostly from Shelsley Special.
  25. banjeaux bob
    banjeaux bob
    from alaska
    Here are 2 interesting GNat pics.Both from Shelsley Special.One show gauges at zero.The other with gauges registering.Here is some abbreviated information regarding GNat from John Bolster's book "Specials".
    Started build in 1925 by E.G. Sharp.
    Shortened and lowered standard G.N. ch***is.
    Wider front axle.
    The engine is a mixture of G.N. engine parts and J.A.P. parts.
    2.75 " ground clearance.
    40mmSolex carbies
    Ignition by 2 single cyclinder magnetos
    G.N. single plate clutch
    this was the first car to run at Shelsley Walsh WITHOUT body work.Eventually it obtained the "KIM" type front sheet metal.
    No front brakes and only one rear brake.
    This was good enough to travel 1000 yards in 50 seconds up the hill at Shelsley Walsh in the RAIN.
  26. banjeaux bob
    banjeaux bob
    from alaska
    Amilcar. G.L. pics
  27. banjeaux bob
    banjeaux bob
    from alaska
    GN Instone Martyr . Stuart Matthews pic.
  28. banjeaux bob
    banjeaux bob
    from alaska
    Here's another GNat image.This one is by Stuart Matthews.
  29. banjeaux bob
    banjeaux bob
    from alaska
    Supercharged Austin Seven Special . S.M. pic
  30. banjeaux bob
    banjeaux bob
    from alaska
    Colin Rogers 1938 ADRO GN J.A.P. .980cc SV/OHV.S.M. pic
