Let's Talk Cyclecars
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Dec 4, 2007.
  1. banjeaux bob
    banjeaux bob
    from alaska
    Roadside repairs.
  2. UKAde
    UKAde
    from Oxford UK
  3. UKAde
    UKAde
    from Oxford UK
    First side of the jappic ch***is in the jig being glued, gets unclamped in the morning
    motoklas likes this.
  4. banjeaux bob
    banjeaux bob
    from alaska
  5. banjeaux bob
    banjeaux bob
    from alaska
    Nice work Ade.I hope the layers don't come undone when you release the clamps.
  6. fur biscuit
    fur biscuit
    whoohoo!!! keep up the progress!! I may have missed it, but what engine do you plan on using?
  7. UKAde
    UKAde
    from Oxford UK
    The original car had a 350 cc ohv single cylinder jap engine , and later it had a 500 fitted I am currently searching or the correct 350 cc engine from 1925
  8. SanctaRosa
    SanctaRosa
    So you've made a beginning Ade, definitely looking good :)
    What glue are you using to laminate your ch***is rails?
  9. chuxx
    chuxx
    Great start, Ade! Happy hunting for that motor....it's out there somewhere. Here's a rough mock up of my frame. I applied the epoxy treatment tonight. ImageUploadedByTJJ1344922491.184292.jpg ImageUploadedByTJJ1344922572.994145.jpg
  10. chuxx
    chuxx
  11. Ned Ludd
    Ned Ludd
  12. SanctaRosa
    SanctaRosa
    What's involved in doing that epoxy treatment Chu**?
  13. UKAde
    UKAde
    from Oxford UK
    Well the ch***is rail is out of the jig , all looks good ,
    It didn't spring back very much at all
    I even plucked up enough courage to place the beam curve up and stand on it , no problem
  14. chuxx
    chuxx
    Miracles of modern chemistry. I'm using a product designed to soak into the wood and seal and protect it from water and bugs. It's called CPES, clear penetrating epoxy sealer, learned about it from a wood boat building site. Kinda like POR-15 used on metal. I live in a high humidity, normally rainy part of Texas.
    Was that your test run, Ade? Or did you use the ash?
  15. UKAde
    UKAde
    from Oxford UK
    We are making the real thing now , 3 layers of 10 mm ash , glued together with west 6 ten epoxy
    1 of 4 is done 2 is in the jig , so number 4 should be done Thursday , then put them through the planer to get them to 100 mm ,
    Then glue the two pairs together using an over sized biscuit joint ,
  16. UKAde
    UKAde
    from Oxford UK
    Beam 1 clamped to the bench to plane the edges , the slot is for the oversize biscuit joint made from a piece of 9 mm ply
  17. SanctaRosa
    SanctaRosa
    Oooooo this going to be such an interesting build to follow.
    Monty Carlo likes this.
  18. banjeaux bob
    banjeaux bob
    from alaska
    Wow! The nuns in New Zealand get to collect stuff from the tipper,build cyclecars,are computer literate ,AND eat popcorn!I'm amazed.
  19. SanctaRosa
    SanctaRosa
    Homemade popcorn is very nice and is quite alright in moderation ;)
    My major interest with cyclecars, velocars and the like is that they are very cheap and effective transport for local journeys. If one is careful wth such things as numbers of wheels, sizes of engines and building in the capacity for light pedal ***istance they can avoid all forms of registration and licencing fees, - or at worst only need to be registered as a moped. All of which is good when folk of very slender means need reliable transport.
    Tip ratting might seem undignified, but if one can find everything needed to build a cheap vehicle by recycling what others throw away, then the whole project becomes a winner all round. Just folowing my vows Bob :D
  20. 64 Wildcat
    64 Wildcat
    Recycling is a good thing, Sister, especially in our little corner of the world... :D
  21. banjeaux bob
    banjeaux bob
    from alaska
    I think I have told you before,you would fit right in here in Fairbanks...on all accounts.Including the popcorn.
  22. UKAde
    UKAde
    from Oxford UK
    Today's jappic report ,
    Pulled 2 of 4 out of the jig, and loaded 3 of 4 into jig had a heart attack thinking I had made 3 of one side , but I hadn't , phew ,
    Cleared off work table and marked out major axis , and other major points like axle centre line etc ,
    Added two sides to table and started on mock up dash bulkhead ,
    Ran out of glue , no stock until Friday , so 4 of 4 will have to wait until Saturday for it's place in the production line
    motoklas and Monty Carlo like this.
  23. DrJ
    DrJ
    This is looking interesting...
    Did I miss a plan of the project?
  24. chuxx
    chuxx
    Always been a ****er for curves. It's so helpful to start the physical layout to see and get a feel for what goes where. Great progress!
  25. UKAde
    UKAde
    from Oxford UK
    Here you go DrJ
  26. Flat Ernie
    Flat Ernie
    Tech Editor
    Always wondered about using the glue they use building airplanes...seems like that should be strong enough! ;)
  27. banjeaux bob
    banjeaux bob
    from alaska
    How about this "cycle"car?
  28. nexxussian
    nexxussian
    Hmmm, base hit propulsion? :D
  29. banjeaux bob
    banjeaux bob
    from alaska
    With plenty of room for a flux capicitor...
  30. I dunno- might look better with some donks... :)
