Technical LH thread wheel nuts
Discussion in 'The Hokey Ass Message Board' started by keith27T, May 29, 2020.
  1. keith27T
    keith27T
    Anyone no were I can get left handed wheel nuts for a 38 chevy?
    Can't seem to find much info.
  2. tb33anda3rd
    tb33anda3rd
    most parts stores should be able to get them
  3. woodiewagon46
    woodiewagon46
    from New York
    You might try Antique Chevrolet, 1-866-767-2787 or The Filling Station, 1-800-841-6622.
  4. tb33anda3rd
    tb33anda3rd
  5. tb33anda3rd
    tb33anda3rd
    the other option is to knock all the left hand studs out and replace with right hand ones so they all match.
  6. keith27T
    keith27T
    That 's a lot of work my friend...
  7. squirrel
    why would a 38 chevy have left hand nuts on it? They didn't come that way, did they? Or is it some weird Canadian thing?
  8. keith27T
    keith27T
  9. keith27T
    keith27T
    Yep
  10. squirrel
    First, did you measure the outside diameter of the stud? and did you measure the thread pitch? And you looked at the threads, and you can see they are left hand?
    If you do all that, then you should be able to find nuts for it.
    Other GMs in the old days, as well as Mopars, had left hand threads on the wheel studs or bolts. But I never saw them on a chevy. Interesting.
  11. keith27T
    keith27T
    I have the nuts but all rusted to hell. Would like to find new ones. Drivers side only front and back.
  12. 38Chevy454
    38Chevy454
    I'm with Squirrel, never seen or heard of left hand lug nuts on a 38 Chevy. Seems kind of odd that Canada would have, and be different than US production.
    My limited experience with left hand lug nuts and wheel studs, there is usually a marking like an "L" on the stud to help identify as a left hand thread. Or on the lug nut, it has lines parallel to the face on the flats. All to help identify as left hand threads.
  13. squirrel
    I was suggesting you measure the studs, not the nuts.
    OLSKOOL57 and Boden like this.
  14. keith27T
    keith27T
    Yes it has L on the studs....
  15. keith27T
    keith27T
    A guess that is what I'll have to do. Was hoping.
  16. keith27T
    keith27T
    Must be Canadian only.
  17. 302GMC
    302GMC
    from Idaho
    Got a camera ? I'd really like to see LH threads on a Chevrolet ……..
  18. keith27T
    keith27T
    I 'll take a pic tomorrow.
  19. Poncho60
    Poncho60
    from N Illinois
    Pretty sure all US GM cars had LH threads on the drivers side thru 1963. Switched to all RH in 64.
  20. Boneyard51
    Boneyard51
    Most lug nut/stud thread are 7/16, 1/2 or 9/16s fine thread , right or left hand. These are available at ,most automotive stores. Some may have to be ordered. These six sizes cover most, car and light truck, for most years. I bet yours is a 7/16 left hand thread.
    Bones
    stillrunners likes this.
  21. keith27T
    keith27T
    Thankyou
  22. keith27T
    keith27T
    Thankyou
  23. jimmy six
    jimmy six
    What??????? Poncho u must not have any old Chevys.... even my 62 were all rights let alone all the thousands I took off changing tires at Sears in the 60’s..
  24. I had a 53 Chrysler and I used jag 94 ad older threaded wheel studs both for the left and right side.
    right side threaded in no prop
    left side I just cut new threads over the Right hand threads and then welded the back of the stud into the drum.
    cheap , easy and now everything was left hand thread find thread just like an old ford or Lincoln.
    took about 2 hours with a few beers.
  25. keith27T
    keith27T
    They probably had to be all replaced, people breaking them taking of the wrong way. Ha
  26. blowby
    blowby
    from Nicasio Ca
    No wonder I keep snapping off studs!
    Max Gearhead and tractorguy like this.
  27. Poncho60
    Poncho60
    from N Illinois
    As was mentioned, if the studs are original they should have an "L" stamped on the end of them.
  28. stanlow69
    stanlow69
    The reason they are rusty, because nobody could figure how to get them off.
  29. squirrel
    No left hand threads on chevys that I know of...I've owned 1928, 39, 50, 55, 58, 61, 63, 66, 71, and some later ones. But Pontiac had them for a while. And since Pontiac and Chevy intermingled up north in Canada, I would not be surprised that it's a Canada thing.
    is it 5 or 6 lug?
    Hnstray, BJR, 49ratfink and 3 others like this.
  30. Budget36
    Budget36
    Hmmn, all the LH nuts I've seen were on the p*** side of Dodges and Semi's, odd (to me) you have hem on the drivers side
    VANDENPLAS and Truckdoctor Andy like this.
