Technical Lift points for a 1960 Corvette
Discussion in 'The Hokey Ass Message Board' started by movin/on, Dec 25, 2025.
  1. movin/on
    movin/on
    Getting ready to take the body off a 60 Vette. No doors, interior, hood, windshield, top, bumpers or rear deck, trim or lights. Plan on having 4 guys lift the body so I can roll the frame from under it. No steering column engine or radiator. All wiring is removed.
    Think I can lift if right next to the frame mounts
    I've got to lift it about 12" from what I can tell. Any idea what a bare body weighs? SBC or BBC are not going back in.
    Richard >>> Movin/on
  2. squirrel
    I lifted one end of the body of my 62 up an inch when it was empty like that, it's not very heavy.
    4 guys should be fine. About 400 lbs max according to the guys on the corvette forum
    old internet photo for your entertainment. The 6 guys shown are not working hard.
  3. movin/on
    movin/on
    Thanks: that's what I thought. Asked the same question on the Corvette Forum over a year ago and never got an answer.
    Richard
  4. oldiron 440
    oldiron 440
    I did a 67 roadster over forty years ago and what I did was put a 2” square steel tube across the body between the body and frame and a similar tube for the front but I had to make a couple straps of steel then went from the first and second body mounts so I had something for the tubing to lift. I put a couple of welds on the tubing to the straps. Doing it this way especially when putting the body back on not damaging the fresh paint or fibergl***. You don’t handle the car you handle the cross bars… good luck
    Paul B, rod1 and vtx1800 like this.
  5. squirrel
    The later bodies have more metal in them, the "birdcage", eh?
  6. Dave Gray
    Dave Gray
    I have lifted quite a few early Corvette bodies from the ch***is. 4 guys can lift it, but 6 are much safer. Remember that the steering column must either be removed first or removed with the body. It is the same when reinstalling the body.
    lothiandon1940 likes this.
  7. COCONUTS
    COCONUTS
    I did a 60 awhile back and the only thing I was told was to leave the doors on or to have a triangle brace at the door opening going from the door latch to where the door hinges are. This is do due to a chance of body flex when lifting the body from the frame. If you notice that it is only the fibergl*** floor holding the body together and if you lift the rear or the front by itself you will notice some body flex. Body flex equals stress cracks. I lifted the body were there was the greatest fibergl*** m***, lateral with the firewall and just behind the door opening on both sides Remove steering column and any other attachments, obtain a case of beer and 4 to 6 guys and lift. Two things to plan for: (1) have a place set the body before you lift and (2) hold off on the beer until the lift, move, and set has been completed. Good luck and remember a body off the frame is like having another car in your shop.
  8. oldolds
    oldolds
    I think that I saw Corvette parts suppliers sell a brace that fits the door openings.
    That's me with my Dad, brothers and a friend lifting my body off in 1974. Most of us were using one hand. I still have the car.
    squirrel likes this.
