Lifting a cab with an engine hoist
Discussion in 'The Hokey Ass Message Board' started by buddyconley, Mar 8, 2009.
  1. Here are pictures of lifting my new rust free former fire engine cab with my engine hoist. I am not sure if this would work with a standard folding hoist, my hoist was a former non-folding, but a few mods and some welding turned it into a folding unit. The reason for this note is my standard folding one has legs that do not come out for extra support, the unit I turned into a folding one, has inner legs that extend out all the way around. Before I pulled the legs out, the cab was lifting the hoist off the ground in the back. Once I pulled the legs out, no prob. I used a standard tow strap wrapped around the cab from above the doors. Note where the strap is, very close to the front windshield, not in the center or the back. This is where I found the cab to be almost perfectly balanced. I belive you could also lift the cab from the side like this to install the cab back on the frame. I will find out once I install the cab back on the frame. I am posting this because I couldnt find a simple picture of somebody doing this anywhere.
  2. Royalshifter
    Royalshifter
    Moderator
    I am one to do everything on my own also and I lift my coupe bodys on and off by running the picker through the door....looks good man.
  3. HOT ROD DAVE
    HOT ROD DAVE
    you will be amazed at what you can do with a picker
  4. Danimal
    Danimal
    Nice. You might like going through the doors and lifting off of the body mount points just to not have it up so high. They **** when you tip one over. Don't ask me how I know...
    AD Chevys rule!
  5. moses
    moses
    just be careful mabey have a fatty stand on the ram end of the picker ...jeffrey
  6. Pinewood
    Pinewood
  7. Kustom7777
    Kustom7777
    from Austin, TX
    not to hijack,,,but how do you guys lift a car body off the ch***is?,,,im getting ready to seperate my shoebox from the ch***is,,and i was wondering if anyone had some good tips......basically, i planned on unbolting the body mounts, jacking the body, sliding some 4 x 4s under it, putting it on jackstands, and rolling the ch***is out.....does that sound ok,,,or is there a better way im not thinking of?
  8. Royalshifter
    Royalshifter
    Moderator
    The jackstand board trick is actually a good one. You could do that at one end and cherry pick the other.
  9. 50dodge4x4
    50dodge4x4
    I think you will find that your picker will be into the roof before you can get high enough to set the cab back on the frame from the side, unless you move the picker inside the cab. We have run a 4" x 6" wood post through the door windows and lifted with the picker under the center of the post. Gene
  10. OldSub
    OldSub
    I've used a cherry picker to take cabs on and off pickups for a while. I need to remove one from a COE soon and wonder how others have done that. My cherry picker is not going to be high enough to remove it.
  11. AV8Paul
    AV8Paul
    I pulled the body off my AV8 a couple of weeks ago. New engine lift worked the balls.
  12. studeboy
    studeboy
    Kinda do mine the same way. I have been using a 4x4 to go thru the door windows and a ratchet strap thru the front and back windows over the roof to hold it in place. I put the boom thru the side window and center the tip of the boom under the 4x4. Lift carefully as the cab will swing if the weight isn't perfectly centered. I have used this method by myself several times and been very successful. I think I may make a block to go onto the tip of my 'picker next time, so the boom isn't at such a steep angle and hitting the door at the top of the lift. The nice thing is if the truck is on skates it can be slid out and the picker doesn't have to be moved reducing the chance of something slipping.
    Sorry for being a little long winded, but I don't have any pictures of it going on or off.
    Hope this helps someone.
    Eric
  13. Rockettruck
    Rockettruck
  14. earlymopar
    earlymopar
    Yep, I do the same as you show in your pictures but always from the side of my 37' cab. For added protection against the single strap slipping and getting off-center, I run a 2nd strap at 90 degrees to the first one (through the windshield and rear window).
    - EM
  15. Kustomz
    Kustomz
    I bolted chains diagonal inside the cab from the mounting points and attached my lift where the chains cross. Took the cab off and put it back on the frame using the same method. Worked great and doesn't have to be lifted all that high to clear the frame.
  16. ol'skool29
    ol'skool29
    thats what my dad and i did with the bed of my 69 chevy, worked perfectly!
  17. Danimal
    Danimal
    We did the Sedan Delivery by putting the chain fall on the front of the body and the cherry picker to the rear body mounts. We lifted it straight up, rolled out the old frame and rolled in the new. Worked like a charm.
  18. hrm2k
    hrm2k
    your way will work fine. We did the original seperation of the 51 fleetline body and ch***is that way while it was outside the garage....sat the body on 55 gal drums
    our 51 fleetline body coming down off the rotisserie wiht the help of our engine hoist. It was touch and go after we added about 500 lbs to the body
  19. bobj49f2
    bobj49f2
    A forklift comes in handy. Here's how I swapped the ch***is in my my panel, took about four hours on a Sunday afternoon:
  20. Carguy365-24-7
    Carguy365-24-7
    Bob that's pretty cool! You could have charged admission ..quite an operation! PAUL
  21. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I lifted my body off with a engine hoist too. I was nervous because the Chevy Bodies have so much wood so I bolted an eye bolt through a 4" x 4" and placed that in the arc of the truck where I thought the most strength was. Then my wife hoisted the back up while I lifted the front up. It wasn't nearly as "hands free" as I would have liked but I had to come up with something since my only "muscle" was my better half.
  22. tikidiablo
    tikidiablo
    from so cal
    I too use a cherry picker throught the door. I put eye bolts through the subrail body mount holes , run chains to them and pick it up slow and easy. One man operation.
  23. lakeroadster
    lakeroadster
    from *
    Some great ideas here and on the linked threads.
    bobj49f2,
    Freakin' awesome still shot video. Makes it all look way easier than it is. Do you have a program that ties all the still shots together?
    Thanks,
    John
  24. That's exactly how I re&re the cab off my truck. Also made for a good rotisserie stand in. lol
    Amazing what you can do when you have no money and are working by yourself................
  25. bobj49f2
    bobj49f2
    I used Animation Shop Pro. I have a remote on my camera and just took a shot every ten minute, or so, and then joined them all together.
  26. JRODHOTROD
    JRODHOTROD
    from Manor, TX
    Cinder blocks and 4x4's to sit on. I use an engine hoist also and work end to end until its off the frame. By myself of course.
