Lifting my banger
Discussion in 'The Hokey Ass Message Board' started by andyman1, May 26, 2010.
  1. andyman1
    andyman1
    from UK
    <TABLE border=0 cellSpacing=2 cellPadding=2 width="100%" height="100%"><TBODY><TR><TD vAlign=top colSpan=3>Can anyone give me the lowdown on making a bar to lift my 4 banger out of my truck. Well actually I lifted the engine out tonight with a rope wrapped around the engine. I didn't really like it so would like to make a bar to put it back in.
    I have read about an angled bar bolted to the spark plug holes [​IMG]
    Will this be strong enough? If so what is the thread size? I think I have inserts that reduce the plug size in my head so do I bolt to them or the original holes?
    Sorry for all the questions!
    Cheers Andy <!-- google_ad_section_end -->
    </TD></TR><TR><TD class=windowbg bgColor=#ffffff vAlign=bottom colSpan=3 align=left><TABLE border=0 width="100%"><TBODY><TR><TD align=left></TD><TD align=right>Link to Post - Back to Top [​IMG] Logged</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
  2. Bruce Lancaster
    Bruce Lancaster
    If you have a couple of full-sized Model A plugs in trash condition...knock out or unscrew, depending on type of plug, the porcelain. Install in each an eye bolt...it should be a good forged one but if all you can get is the bent-from-rod kind weld the gap where the eye closes solid.
    Don't lift from adaptors...small threaded holes in aluminum.
  3. Hey Andy. I made one of those bars to lift mine. It works a treat.I just copied the one I saw in the Macs catalog. I'll post a pick when I get to my computer.
  4. andyman1
    andyman1
    from UK
    Thanks for that, Bruce and Cactus1, I will look out for the photos.
    I don't have any old plugs as this is my first Banger.
    Cheers Andy
  5. Here you go Andy. The angle iron is a piece I had 2"x3" x 1/4". As Bruce said, it uses two destroyed spark plugs and some grade 8 bolts. I had to ease the corners on the bolts to get them through the spark plug holes. I lifted mine complete with trans installed, no problem. Hope this helps.
    Sorry for the crumby phone pics.
    -mikethegreek-
  6. andyman1
    andyman1
    from UK
    Cheers thats great!
    Thanks for all the help.
    Andy.
  7. Yep...this is a great one!
