Hot Rods Light rear shock
Discussion in 'The Hokey Ass Message Board' started by butch27, Oct 14, 2017.
  1. butch27
    butch27
    I need a very lightweight rear (reg.hydraulic) shock for the t bucket. I need loop on both ends I have a regular over the counters on now but they are just too heavy of weight. I know Speedway has some but they may bee too heavy also. My car weighs 1700 with a small block Ford. Thanks Butch
  2. Kerrynzl
    Kerrynzl
    If you can find any, just lay them over and alter the "motion ratio"
    dumprat likes this.
  3. tfeverfred
    tfeverfred
  4. nobux
    nobux
    RICH B likes this.
  5. RICH B
    RICH B
    Yep
    zzford likes this.
  6. butch27
    butch27
    Nobux---That'll work
  7. butch27
    butch27
    May need a insert for 5/8" bolts.???
  8. nobux
    nobux
    I'm pretty sure that I had to drill the eyelets out to 1/2". I can't remember what size the hole was originally. They are skinny, 1-1/2" diameter vs the 2" the 73-87 Chev truck shocks were.
    http://www.monroe.com/en-US/e-catalog/31089/
  9. butch27
    butch27
    Yes--1/2" drill out Thanks
  10. butch27
    butch27
    Don't think the Chevy truck would be of any help ??
  11. nobux
    nobux
    My bucket weighs 1600lbs, so pretty close to yours. The Chevy truck front shocks were so stiff, it took a full on body slam of my 180lbs to get them to cycle. The VW shocks can be cycled with one hand.
    I discovered that early MG guys were using them with good luck because of similar car weights. I gave them a shot and they worked.
  12. butch27
    butch27
    One guy sugested air shocks. What do you guys think ??
  13. RICH B
    RICH B
    Maybe there are different versions; but I have found that (on O/T cars) air shocks at the minimum pressure were pretty stiff; can't imagine them functioning on a "T".
  14. DdoubleD
    DdoubleD
    from Michigan
    Check Pete & Jake's they sell a shock that is non-gas oil only damper. I switched to them on my pickup made a big improvement in the ride quality.
  15. butch27
    butch27
    Thanks everyone. The VW ones sound about right and in the same weight region.
  16. butch27
    butch27
    Problem--My mounting length is 12" sooo I need a shock that extends to about 14" BUT
    compress to around 9-1/2" ??
  17. tfeverfred
    tfeverfred
    Butch, check out Speedway. I'm sure they have those.
  18. X-cpe
    X-cpe
    Butch,
    My car weighs 2,000 lbs. I believe the original application was 60,s Vette rear. Got them from Sears in the 80's. Part number is 93858, also has a line that says C0031. Loop top and bottom. bottom fits a 5/8 stud and the top has 5/8 hole sleeved to 7/16. Travel range 9 1/2" to 14". Don't know if these will be soft enough.
    Outback and RICH B like this.
