Lighter Tech? 6v to 12v...
Discussion in 'The Hokey Ass Message Board' started by 4woody, Nov 17, 2003.
  1. 4woody
    4woody
    Doing a 12v conversion and got to wondering if the lighter cares what voltage is run to it. Can I just give it 12 and it's ok that way?
  2. Paul2748
    Paul2748
    Don't know but smoking is bad for your health [​IMG]
  3. Deyomatic
    Deyomatic
    from CT
    I don't know, I think my 55 Fairlane would have been 6v to begin with. If so, someone converted to 12 volts sometime, and my radar detector still works in the 48 year old recepticle.
  4. DrDano
    DrDano
    Alliance Vendor
    I would stick a voltage drop on there just to be safe. No sense in having a fireball for a car because of the cig lighter.
  5. Detonator
    Detonator
    from santa cruz
    so what's an athele like you need a lighter for Hugh? Oh yeah, this is Santa Cruz, dude like I forgot what we were talking about....
  6. ESnacky6
    ESnacky6
    Hahahahaha..!! Good one...
  7. Elrod
    Elrod
    You could take the original knob and put it on a 12V element....
  8. Petejoe
    Petejoe
    from Zoar, Ohio
    I would think those elements would take the 12 volts. The 12 volt systems have less amperage than the 6 volters. The elements are designed to pop out after expanding from the heat. The 12 volts may just heat it up alittle faster. I installed a new repop 6 volt lighter after I changed over to 12 volts on the coupe because the original lighter was missing. It has been working fine by me. But I would still give you a word of caution, The heat coming from those things can light up a car along with a cigar real quick.
  9. 4woody
    4woody
    It's not that I'd actually use a lighter,I just hate to leave the job part-way finished...Might want to plug in an accessory... or... [​IMG] something.
    So do we think the 12v wants a different element, but the recepticle is the same, or is it just wisecracks from here to the horizon?
  10. Elrod
    Elrod
    The receptical will be fine with 12 Volts. It's just metal contacts in there. You should be able to plug in cigarette lighter accessories like cell phone, etc just fine.
    It's how the little coil in the lighter knob will react which has me guessing.
    Pull the dang thing outta the dash and hook it up to a car battery and see what happens. It's not going to explode or anything. Just might heat up really fast, or might do nothing at all. Post what you find.
