Projects Lights or Hidden Lights
Discussion in 'The Hokey Ass Message Board' started by swade41, Aug 26, 2018.
  1. Lights
    94 vote(s)
    87.9%
  2. Hidden lights
    13 vote(s)
    12.1%
  1. Headlights are for seeing and to be seen. You need to make sure people can see you driving at night.
  2. Dick Stevens
    Dick Stevens
    37 Ford headlights may look very good installed in those fenders! Definitely would not mount them behind the grill!
  3. swade41
    swade41
    from Buffalo,NY
    You can't see this ?
  4. wraymen
    wraymen
    Put one in the scoop and make motorcycle noises.
  5. swade41
    swade41
    from Buffalo,NY
    These grills are ridiculously overpriced, I dont think I want to go cutting it up.
    To answer your other question about in the fender, now to me that is streetrodderish.
  6. KustomKreeps
    KustomKreeps
    dude just look at that light pattern! Its utter **** with shadowy bars through it.
    are you willing to risk your life, your p***engers life and any other person on the roads life?
    Hate to have to drive like that on the open roads.
    The early 50s Buicks had a marker light housing with grill bar/teeth on top or bottom. Added into your front fenders they may work with your grills bars. Add motor cycle headlights or LEDs.
    Or just keep them up top.
  7. wraymen
    wraymen
    I would not cut it up either. Maybe some smaller really bright lights between the bars.
    Clik and swade41 like this.
  8. swade41
    swade41
    from Buffalo,NY
    A perspective and a lecture are way two different things, I'm a grown man, even drove truck over 20 years, I think I know the ramifications of the law.
    If I didn't think I could see or be seen I wouldn't even consider it and yes I'm pretty sure the direction I'm going in with the lights but maybe there's another "suggestion" out there. Maybe someone knows about some tiny lights that put out a million candle watts that'll fit between the grill bars or where I have the turn signal/parking lights ???
  9. swade41
    swade41
    from Buffalo,NY
    Uh, I have a motorcycle, but I can't post it on here, so I'm good there..hahaha
  10. Jalopy Joker
    Jalopy Joker
    might want to look at interior again with that statement - lots of options for running headlights on/in fenders out there
    chryslerfan55 and 5window like this.
  11. saltflats
    saltflats
    from Missouri
    That's on the lines I was thinking.
  12. XXL__
    XXL__
    Thanks for the clarification. As a responsible one of those, maybe keep your lights fully operational and safe, and you can take off the lights to look like a salt racer next time you take it to the salt.
  13. Joe H
    Joe H
    Use a hideaway head light in the fenders, open when on, closed when off. GTO, Vette, Buick, surely something could be made to work better then behind the grill. Low to the ground like they are, you might as well just call them running lights or fog lights, because out on the road, all you will see is just above the road surface, not whats coming at you!
    chryslerfan55, loudbang and upspirate like this.
  14. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    Forget the bright red paint and rib bumper , this design would be your best solution. The hidden headlight look was actually used quite a bit on late 30's early 40's gm rods in the late 80's . Of course so was pastel paint!
    But one I remembered was a 40 Chevy with a blown block and big tires. A street rod? I guess it depends on your perspective. But most would be changing your shorts after riding in it!!! I build cars to suite my taste, no one else's. But I always build safety first . I vote for the smooth look but with lights exposed. Be creative, just not rectangular ! lol Larry
  15. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    Better yet check out the Photo shop thread and see what moose did to your truck with the picture **** Stevens posted for you. I like it!!!!!
    chryslerfan55, loudbang and swade41 like this.
  16. a photo outside a garage vs driving at speed on a highway is a different story.
    just please be careful with what YOU decide to put on the road. Hide-a-way headlights work. But function over "cool factor" is king.
    Even the Y-Job has hidden headlights but correctly been seen at night was key.
    Ah, good luck anyhow.
  17. swade41
    swade41
    from Buffalo,NY
    I think I know what I have, it sure ain't no damn street rod.
  18. ken bogren
    ken bogren
    Hidden headlights like a 42 DeSoto?
  19. swade41
    swade41
    from Buffalo,NY
    Whoa, no like, it makes the front look way to wide. I originally nixed the headlights from the original location for that very reason, I wanted more fat fender look up front to match the roundness of the top and full roundness of the rear fenders. You know a visually wider/curvier front fender.
  20. 5window
    5window
    Being able to see bright lights from in front of your truck doesn't necessarily correlate to being able to see the road from inside your truck. If you already had decided what you were going to do, why start a thread and ask for advice or opinions? If you do want opinions, why not respect that 95% of those polled don't favor the idea. Your truck, you decide, but don't get mad if folks disagree.
    chryslerfan55 and XXL__ like this.
  21. 5window
    5window
    State of New York Vehicle and Traffic Law: " d) A motor vehicle, other than a motorcycle, equipped with any device such as, but not limited to, a snow plow blade, which blocks or impairs the projection of light from the headlamps of such vehicle, shall be equipped with at least two additional headlamps on the front which headlamps meet all the requirements of this subdivision for headlamps except those provisions of paragraph (b) of this subdivision specifically limiting the height of the beam of any headlamp." All you need is one grumpy police officer.
    loudbang and gimpyshotrods like this.
  22. Hnstray
    Hnstray
    from Quincy, IL
    That's called a "distinction without a difference"..........further, you ask for opinions, receive them and reply with a disgruntled at***ude. If you know what you like and do not like, why bother to ask. You get useful references to laws that are worthy of consideration and you call it a 'lecture'....perspective, if you had it, would reveal a pattern here.
    scotty t, Peanut 1959, XXL__ and 4 others like this.
  23. Barn Hunter
    Barn Hunter
    I like the smooth look without the frog eyes. Just don't know the best solution. Actually I do like the original type half in/half out of the fender top, similar to the 46-7 Studebaker truck lights.
    5window and lothiandon1940 like this.
  24. Dick Stevens
    Dick Stevens
    Did you just want agreement with what you have chosen, or why would you start a thread and a poll when you aren't going to consider what the vast majority have voted to do? I happen to think this is a good look but we all know opinions are like ***holes, we all have them and it is your prerogative to ignore ours.
  25. 1946caddy
    1946caddy
    from washington
    Is that going to be a big spotlight sticking up threw the hood? :)
    clem and 5window like this.
  26. hotcargo
    hotcargo
    to my way of thinking..............stock lights but moved in towards the centre 1 inch or 1 1/2 inches per side
    steve in Oz
    Peanut 1959 likes this.
  27. swade41
    swade41
    from Buffalo,NY
    Why are you ***uming the direction I'm going in ???
  28. Jalopy Joker
    Jalopy Joker
    x2
  29. swade41
    swade41
    from Buffalo,NY
    Oh boy, I'm not disgruntled but I sure can be if you want me too.
    I have a poll about headlight location but instead I do get a lecture on state laws, twice mind you and now you want to be my psychiatrist or English teacher, which one I'm not sure of.
    Some want to call my truck a street rod which again has nothing to do with the poll and another guy wants to imply I have a death trap, "
    yanks can drive some real road kill death traps"
    In NY state we have to get inspections once a year, I have 6 licensed vehicles plus a car trailer all on the road getting inspected. I think I know how it goes more so than a person that doesn't even live in the state !
    Again it's a simple poll about headlight location, nothing more nothing less. If you read my posts I even said that maybe someone knows of a small light to hide that will provide ample light I'm all ears.
    But I'm certainly not going to cut my grill, put the stock lights on or cut my fenders up to put in lights I don't want just because someone here likes it.
    I've owned this truck for over 25 years and almost all of those years I've thought about these headlights. I've ran through most any location and style in my head or during mockup in that time. I narrowed it down to 2 possibilities which I provided a poll for, evidently I must not understand the poll process or something.
  30. swade41
    swade41
    from Buffalo,NY
    This was a strong possibility but I had them in even further than that. What I did was measured the width of the rear fenders and brought that measurement to the front. I then duct taped the stock lights inboard so the front fender from outside lip to headlight equaled the width of the rear. A problem I ran into was the headlight pod ran into the hood sides before I could get that equal width look.
    I might even have a photo of that still.
