Technical Lights reflecting between windshield and rear window
Discussion in 'The Hokey Ass Message Board' started by altraditional, Nov 29, 2015.
  1. altraditional
    altraditional
    from Estland
    Hey, Model A PU has a silly problem, when driven in dark, the lights from the car behind me tend to keep reflecting between windshield and rear window. Must be parallel gl***es. So it looks like tens of cars, reflecting to my eye from the windshield.
    What have you done to prevent it?
  2. flamedabone
    flamedabone
    It's like driving inside of a Rubix Cube, ain't it?
    Open your front windshield a bit and you will be fine. You can also chop it a bunch to cut down on the problem...
    -Abone.
  3. Rusty O'Toole
    Rusty O'Toole
    Lots of old cars had a window blind in the back window, this is why.
    Multiple reflections occur because the gl***es are flat, and are both vertical and parallel. When they started slanting the windshield and back window the problem disappeared. Some custom built twenties town cars and limos had forward slanting windshields for this reason.
    Opening the windshield changes the angle of reflection. I don't know if tinted gl*** would help.
  4. 325w
    325w
    Gray tint doesn't help. Cataract surgery helps some!
  5. altraditional
    altraditional
    from Estland
    Yea, bad part is, the windshield is fixed on mine! And curtains are not exactly what I want.
  6. aaggie
    aaggie
    There isn't a real cure for the problem. The old cars were not driven much at night because the bulb lights were more for you to be seen and not for you to see where you were going. A blind or curtain may be your only option if you have to drive at night.
  7. Mr48chev
    You might try one of those sunshade things that people put in back side windows to shade the rug rat in the car seat. Tuck it away in the day time and put it up when you need it.
  8. woodiewagon46
    woodiewagon46
    from New York
    Thats why Model A Fords had an optional window shade. Most people think it was for privacy but it was for glare. I wear gl***es and it seems 10x worse, I don't even want to drive at night anymore.
  9. flamedabone
    flamedabone
    Model A trucks had a flip out windshield when they were new. Can you un-fix it?
    Got any pics?
    -Abone.
  10. jaw22w
    jaw22w
    from Indiana
    I have a 26 T coupe. The reflections are really bad. It's not only the front and back windows. The side windows do the same thing. In a lot of traffic at night, it can be very confusing. My T came with a curtain in the back window. I'm going to try it.
  11. 29moonshine
    29moonshine
    solar screen over the rear window will help
  12. gnichols
    gnichols
    from Tampa, FL
    And when you add in a vintage style, flat rear view mirror, the fun even gets better. My next build will have one of those two gl*** panels tilted, to fix just what you are describing. I hate it. Gary
  13. 33sporttruck
    33sporttruck
    Load the bed with Hay Bales and strap them down. Light will not come in through the back window and the hay bales will make it look traditional............................. Jeff
    Truck64 likes this.
  14. Jalopy Joker
    Jalopy Joker
    later cars have similar problem with mirrors. why there are Day/Night mirrors and tinted outside rear view mirrors. wear sungl***es. get dark tinted flat gl*** framed and set up an electric track to raise and lower in back window. but, then there is the side gl*** problem.
  15. flt-blk
    flt-blk
    from IL
    I have seen into other dimensions through mine.
    My two best solutions:
    - lean towards the door and look at an angle
    - hang my black hat on the rear view mirror to block some reflection
  16. O
    Swing the windshield out, helps a lot!
