Lightweights: <1500#
Discussion in 'The Hokey Ass Message Board' started by sgtlethargic, Jan 10, 2012.
  1. Shaggy
    Shaggy
    from Sultan, WA
    I figure my dads 27 roadster project should come in close v-8 60, model a banjo ect....
  2. krooser
    krooser
    They were the basis for the SCCA "Formula Ford" for around 40 years...
    When I worked for a Ford dealer in the 90's Ford Motorsports had a good selection of everything.
    http://www.thekentlives.com/thekentengine.htm
  3. krooser
    krooser
    Is with or without the cheese?
  4. leon renaud
    leon renaud
    from N.E. Ct.
    I don't know how rare they might be but Ford did make a bell housing around 72-3 that would bolt up to any of the Pinto 4s.I had a 72 pinto that came with the 1600 but in 72 the 2,000 was an option the bell housing fit both engines I blew the 1600 and bolted in a 2000 using the same trans and bell housing even later I swapped out the 2,000 for a 2300 still using the same bell housing.I was told back in 1980 by a Ford mechanic that that bell housing was offered just the 1 year that both the 1600 and 2,000 were offered! A lot of changes were made between the 73-4 model years also
  5. metalshapes
    metalshapes
    Bellhouse pattern of the Kent, Pinto ( both 2.0 and 2.3 ), CVH, and I believe Zetec are all the same.
    There are some differences in the flywheels.
    ( I'm bolting a close ratio racing gearbox that was made for a 1500cc pre-crossflow to a 2000cc Pinto.
    It fits, but I'm a bit worried about its strength...)
  6. Johnunit
    Johnunit
    from Toronto
    bump... interesting thread idea.
  7. falcongeorge
    falcongeorge
    from BC
    How about Dirty Dougs car with an aluminum block flatty? Period correct, and might get pretty close to the 1500lbs...
  8. Where did the other 1.4% go? :p
  9. Real car was said to try to keep the yucksters from replying with Hot Wheels or somethin.
  10. 28hiboy
    28hiboy
    from Milton, Fl
    Maybe on the Front or Right.
  11. On the Pinto bellhousing: I got one from behind a 2.0 L in a Capri and the bolt pattern for the transmission is different than what came with my 1.6 L.
  12. milwscruffy
    milwscruffy
    Did a 30' A coupe in the 80's and that weighed in at 1581. Built with a .083 tube ch***is with a 301 chevy , M-22 and 513 geared early chevy 10 bolt rear. Took a lot of doing to get it that light and you could watch the frame twist when you got on it. Scared the **** out of me and whomever was in it with me at the time. Never made it past 3rd gear on it.
  13. nexxussian
    nexxussian
    I would suggest the Stalker V8, but it uses an OT engine to keep the weight down (claimed 1460 Lb wet).
    Some T buckets have to be that light though, if you put it together with say a 215 Buick (3.5 Rover) it shoudn't be too hard to keep a vehicle under that.
    The Fellah that built the roadster around a Tempest 4 drivetrain got close as I recall.
    Would be a fun "go kart" like ride, brutal under acceleration with the right combo (especially since cushy seats are heavy ;) ).
    Of course that light and you could make it brutal in all directions if you got the handling sorted. :)
    Is your sub 1500 Lb benchmark because you are trying to get under some rule or regulation (ie "officer Fife" issues)?
  14. Dirty Dug
    Dirty Dug
    215 Buick, I always thought that would be a great car.
  15. Shaggy
    Shaggy
    from Sultan, WA
    I think a tin side v-8 60 comes in just under 400#'s too and it that aint enough you could always throw an OHV kit on it and make it around 80 or 90 hp in stock trim
  16. nexxussian
    nexxussian
    OHV setup would likely weigh more than a blower, if you could find one small enough.
    Lysholm maybe?
  17. metalshapes
    metalshapes
    1st number is half of the left /right weight distribution,
    2nd is half of the front /rear.
    Numbers went to
    Left - 52%
    Rear - 49.2%
    With me in the driver seat.
    A p***enger and a full tank of gas should put more than 50% over the rear wheels...
    Really surprised your 2.0 bell didnt fit the 1.6
    Sure it wasnt from a V6 Capri?
  18. Kerrynzl
    Kerrynzl
    You need the bellhousing to match the gearbox, there is 2 common sizes.
    2.0 is the larger gearbox pattern and 1.6 is the smaller pattern
    The bellhousings will swap over on the engines
    All Kent, SOHC, CVH , Zetec Ford engines have the same bolt pattern at the back of the block
  19. Jimv
    Jimv
    I took my T to the scales at the local s****yard & with only a littl gas in it it weighed 1685, its a T bucket, steel wheels, 400 SBC , TH350 & a ford 8" rear.
    JimV
  20. brandon
    brandon
    My track t project is pretty light but unfinished, so no weight yet....20r 5 speed gl*** body t...2x3 frame....
    Yesterdays bs bench racing build.......same style car as above, with a round tube ch***is, about 8" longer wb....small 4.8 ls motor, glide or 350 turbo & 9"......maybe with 70mm in track nose.....4 link suspension....suspension
  21. customcory
    customcory
    This one was 700 pounds according to the article inside.:D
  22. Paul Y
    Paul Y
  23. turdytoo
    turdytoo
    For what it's worth, In California when I was much younger,to be fenderless your car had to weigh less than 1500 lbs. Lots tried and lots got tickets for trying to bs their way out. American mag 12 spokes and motor cycle type wires were typically part of the attempt. It was done but it wasn'y easy.
  24. Ned Ludd
    Ned Ludd
    Take a look at Austin Seven specials:
    Stock early Seven tourer was 800lbs, equipped and road-legal. Specials are possibly a bit lighter. There's a lot of weight to play with to 1500lbs.
  25. mpg
  26. Positive- I pulled it myself.
  27. That's good to know; I may look for a 5-speed transmission.
  28. Mr48chev
    With the sbc & cast iron glide it went across the scales right at 1500 with exhaust and what served as the interior. In the early 70's we shot for under 1500 lbs on T buckets.
  29. gnichols
    gnichols
    from Tampa, FL
    http://www.streetrodderweb.com/featu.../photo_02.html
    Everytime I see photos of this car I wish it was mine. It's one of those perfect builds, a hot rod / sports rod / special that is built to be a reliable, "fully functional" car like the Shelby Cobra was. The fact that it's fairly light is just another plus. Gary
  30. TomWar
    TomWar
    Dawie: a Morris Minor or Sprite engine only weighs about 150 lbs.
