I am runnin Limefires with no down tube outlets, wondering if anyone is making a baffle I can install in thes to cut the noise down at higher rpms, ive seen some dynatech's in a speedway catalog for sprint cars, any others out there, thanks much
I just built some for mine. I used aircooled VW 'stinger' baffles. Available at BAP auto parts stores cheap. Heres a link with a couple pics: http://www.midnightersphoenix.com/forum/viewtopic.php?f=6&t=27
I made my own out of a few washers & some tubing. (sorry, no pics, & I don't use em any more) It's cheap, easy, & effective. Do a search & you will find lots of threads about homemade baffles & the different techniques folks use to make em.
Made my own out of 3" VW Stinger Baffles cost like $45 bucks from a dune buggy shop. They slid in with a little grinding on the inside welds of the limefires cones. Then I drilled the limefire block off caps and bolted them back on. The extra block off caps from Sanderson ran around $70 for the pair.
