Technical Lincoln 1941 V8 ?
Discussion in 'Traditional Hot Rods' started by 3w Hank, Aug 8, 2023.
  1. 3w Hank
    3w Hank
    One told me Lincoln made flathead V8 1941 as the special deal was the 90 degree that came out of cranks main centre, not moved out as the Ford V8 flatheads.
    Called ’tall deck’ or tall block.
    So whats the story here ?
    -The block ( Lincoln or not ) was in front of me but I could not say if the flat surface where intake goes at was taller than a Ford V8.
    When I now searched all Lincoln 41 had a V12, but it was a huge V8 later 40’s but 850 LBS...
    This must be a Mercury 1941 block as it did look like a 59AB.
    elgringo71 likes this.
  2. scotts52
    scotts52
    Most likely a later 337 Lincoln Flathead
  3. 3w Hank
    3w Hank
    Did look like a 59B as a it was several 59 BA beside.
    Same waterpumps.
    Deal was ’it was’ a Lincoln 1941 and V from centre of main.
  4. alchemy
    alchemy
    If it’s the same size outside as a Ford or Merc, it’s not a Lincoln.
    Illustrious Hector likes this.
  5. tubman
    tubman
    Count the head bolts/nuts on one head.
    17 - V8/60
    21 or 24 - Plain old Ford or Mercury
    27 - Lincoln or Ford truck
  6. 3w Hank
    3w Hank
    Ok, Thanks.
    That has the Tatterfield heads 24 bolts and 4 inline carbs.
    So Ford or Mery, but if a Lincoln it did sounds cool.
  7. sunbeam
    sunbeam
