lincoln 368 = y block = what fits from other motors
Discussion in 'The Hokey Ass Message Board' started by touchdowntodd, Oct 24, 2005.
  1. touchdowntodd
    touchdowntodd
    like it says, gettin a 57 lincoln, keepin stock valve covers cause they are tOOOO cool.. but what other yblock stuff is interchangable?? intakes? valley covers,. gaskets, etc........................... school me boys....
    and oh yeah, anyone got cool pics of 57 lincolns, not the dagustino one either, LOL.. have about 34038950 pics of it already
  2. Chris 50
    Chris 50
    Do you have the original hupcaps with that Lincoln? If so, any interest in selling them off?
  3. Thirdyfivepickup
    Thirdyfivepickup
    LOL...:rolleyes:
  4. touchdowntodd
    touchdowntodd
    might have em for sale.... but if i get rid of em, wil be trading i think.... will let everyone know... but way to hijack the thread, LOL
  5. Uncle Scooby or 286 Merc should be able to fill you in, but not much interchanges. You mean you've got these kind of valve covers? Very cool.
  6. touchdowntodd
    touchdowntodd
    i dig the mark ones too, but i have the regular gold lincoln ones with cool writing... hehehe.. not sure why, but i LOVE em
  7. 286merc
    286merc
    from Pelham, NH
    Nothing from a Ford Y block. Some stuff swaps from the 302/332 Big Truck blocks and thats it.
    BTW, dont leave that Lincoln on the street at night; Ive been looking a long time for a 368 to put in my 54 F350!
    jimmy six likes this.
  8. bubba22349
    bubba22349
    Depending on what you want to do with the 1957 Lincoln you have most all of the best parts for hot rodding. They had the ECU heads, 57's has extra reinforcing with bigger exhaust valves (for performance use is the best), has the higher ratio rocker arms, a fairly good intake and the best distributor.
    For interchange these all used the 368 so their parts would fit 1956 & 1957 Lincolns & Mark II, 1957 Mercury Turnpike Cruiser. There were some Hi Po 368 parts offered through Ford and Holman & Moody in 1957 for the 368 and in the Mercury a Hi-performance engine package for racing called an M335 for its 335 HP rating. Had fined aluminum valve covers with M335 in the center, dual quad intake, a hot cam, stick bell housing and flywheel, really rare stuff.
    1955 Lincoln had a 341, and the 1952 to 1954 Lincoln’s used the 317 engine all are the same engine design and the parts would bolt on though you would not be gaining any power with the older heads, they had less compression, intakes ports and valves are smaller too. The big Ford trucks (around the F600 to F800) up to 1963 used this engine in 279, 302, 317 & 332 sizes some truck parts that might be worth considering besides a block are the 1960 - 63 intake Holly 4V bolts on, they had a set of Rams Horn exhaust manifolds that might be worth a look. The 302 & 332 cranks are forged steel and same 3.66 inch stroke as the 368 they have been welded and easily stroked to 4.00 inch and sometimes even to a 4.10 inch. Some are using the truck cam for more bottom end torque too.
    From a Y block Ford the only parts that can be swapped to the Lincoln’s is the distributor some are using 57 up unit because of better advance (you need to change to the Lincoln gear) the oil pump and its drive would also need to be used with this combo.
    If you run across any extra parts I have a 1954 317 engine that I want a few parts to hot rod it with. Would like to find a set of the ECU heads and 1956 or 57 rocker arms, 57 distributor, truck steel crank, 56 or 57 flywheel, trans bell housing, and throttle linkage Aluminum valve covers and either dual quads tri power or a blower setup.
  9. unclescooby
    unclescooby
    from indy
    Speed parts are really hard to come by for these motors but check on Ebay with a fellow called "vintakes" in California. Lincoln speed parts are his specialty and he usually has a few hot NOS cams and occassionally an intake. The valve covers are expensive but cool. I saw that Lincoln for sale and thought it was bitchin. I used to have a 57 two door. It's a lot of car.
  10. rockabillyjoe
    rockabillyjoe
    from Seattle
    The 368 is an awesome motor. The biggest drawback is finding parts for them. I am wrapping up a rebuild on mine for my premiere. .40 over pistons, Re worked heads, I had the hardest time finding a cam for it. (the orig had a chipped dist' drive tooth.) So I sent it out to be repaired.
  11. 22 track
    22 track
    The stock valve covers are nice, but Vintage Speed is now reproducing the Edmunds aluminum valve covers for this engine. A picture is about 2/3 down the page at this link:
    http://www.vintagespeed.com/
  12. unclescooby
    unclescooby
    from indy
    Royce is another good source of information on this motor...CHeck his site here on the Mercury Mermaid...
    http://home.g2a.net/~brechlrl/
  13. touchdowntodd
    touchdowntodd
    thanks guys.... my valve covers are all painted up nice and all, so maybe i can ebay em for enough to come close to byuin those edmunds ones!!! ive seen teh stock ones in decent shape go for $150 before... i cant WAIT to get this car drivin.... single 4bbl is cool with me, not tryin to hop it up too much due to costs... but valve covers would be cool.... need to get rest of car done first, LOL.............
  14. cobrabreeze
    cobrabreeze
    from Renton, WA
    I sell a "Hot Rod Lincoln" kit for the Lincoln Y-Blocks:
    * Limited edition QuickTime bell housing for TKO/ TKX or T5.
    * Limited edition McLeod 28# or 40# Steel flywheel
    * PowerMaster clockable mini-starter
    * Pilot Bushing
    $2000
    Production run of 10 units
    Fred Sanderson
    Dark Horse Performance
    425-227-7778
    Adriatic Machine and vtx1800 like this.
  15. BJR
    BJR
    Way to resurrect a thread from 2005 to sell your new product.
  16. drtrcrV-8
    drtrcrV-8
    There is a sort of "underground" for these motors, so don't be shy with questions or any odd info, even though some of the most knowledgeable are gone (RIP Rich Fox!!), there are others still lurking & attempting to carry the "flame" for those of us masochistic enough to dabble with the "Y-Blocks" bigger brother... LOL!
  17. jimmy six
    jimmy six
    There are a few Mercury/Lincoln Big Y-Blockers on the Yblocksforever.com page….really god guys with a lot of knowledge. Good Luck.
