LINCOLN Flathead V8
Discussion in 'The Hokey Ass Message Board' started by The37Kid, Jul 18, 2006.
  1. The37Kid
    The37Kid
    Saw a LINCOLN Flathead V8 today, not a late 1930's item,looked like something from the 1940's. Left side head had LINLOLN in script cast in it. What was it?
  2. old beet
    old beet
    Hot Rod Lincoln...........OLDBEET
  3. The37Kid
    The37Kid
    Could be someday. Aside from the one in the song did anyone run these in Hot Rods? Looked like a slightly larger Ford/Mercury Flathead.
  4. old beet
    old beet
    A few in Hot Rods, but pretty heavy. 337 cu. in. I think.......OLDBEET
  5. old beet
    old beet
    As a side note, Chalie Ryan told me," it was'nt real fast out of the hole, but would run at high seed all day long". He still owns it, and brings it around once in a while.........OLDBEET
  6. Stick Shift
    Stick Shift
    from LENA IL
    A buddy is going to run one in his chopped t sedan. He said the ole motor weighs a lot!
  7. twofosho
    twofosho
    Saw a blurb on the Charlie Ryan car recently, maybe here on the HAMB. Could swear I read the car has been restored and is still running the original Hot Rod motor, and it's a V12 not a V8.
  8. old beet
    old beet
    V-8...............................oldbeet
  9. twofosho
    twofosho
  10. Jive-Bomber
    Jive-Bomber
    MODERATOR
    Ah yes-- the Lincoln 337 Flathead V-8 ran in the 49 - 51 Lincolns and Ford F-7 and F8 trucks (but with solid lifters).
    The good news: They sound mean, rebuild parts are availble for Kanter, and they make the flathead guys look twice. Also came with a 3 speed OD stick or Hydramatic trans.
    The bad news: Speed parts are RARE and expensive, and the motor weights a TON.. Seriously- It bent my cherry picker pulling it out.
    I ran my 49 Lincoln Cosmo for about 4 years with that motor and it never died-- The ****** gave out first.
  11. The37Kid
    The37Kid
    Thanks for the quick history lesson. I've seen the inside of a late 1920's Lincoln V8 with the fork & blade connecting rods, that engine looked like a real piece of art.
  12. Digger_Dave
    Digger_Dave
    Ford identified the engine as a 8EQ.
    Manufactured from '49 to '54. (no '54 isn't a misprint; Canada continued manufacturing flathead engines until late 1954)
    It was used exclusively in F-7, F-8 trucks and Lincoln cars, and it was a monster! (over 700 pounds)
    This engine can easily be identified by the location of the distributor, which is at the rear, on top of the block, next to the fuel pump and by the external water byp*** tubes.
    The 8EQ engine displaced 337 Cubic Inches and developed 145 horsepower.
  13. plan9
    plan9
  14. Hi , i´m building a A roadster and have this Lincoln flathead lying around.
    I will use 32 frame with boxing plates to carry all that weight , lets see how it goes , at least you dont see those everyday...
    Old picks anyone???
    AVG
  15. Little Wing
    Little Wing
    from Northeast
    337 no real speed parts and weight a Ton This intake was off of one..
    the 1950 Lincoln one had HYD lifters
  16. Seen a few in old trucks and at farm shows running pumps. Neat old engine, but as said before "Heavy".
  17. Ole don
    Ole don
    I knew a fellow who drove a 49 Lincoln four door to work once in a while. He came off a cloverleaf once with a Camero right on his bumper. When the road straightened out, he floored the Lincoln from about thirty in third gear. He heard the Camero ****ing air, but it didn't go by until the Lincoln was doing 60! Anything you hear about this being a torque monster? Its all true!
  18. Lets see what it will do in 29 roadster...
  19. Lets see what it will do in 29 roadster...
    I try it first with the original intake manifold ,but it´s no biggie to improvise new one from tubing / scratch...
  20. holeshot
    holeshot
    from Waxahachie
    hey KID...where in the world would you find parts for that mill? they would break howard hughes! and i must confess, i didn't know ANY flathead had hydrolic lifters. but they are not my expertice. call me POP...or the old FART!
  21. Little Wing
    Little Wing
    from Northeast
    well they say
    "what you don't know could fill a book"
    http://www.vanpeltsales.com/FH_web/flathead_specs-337bigV8.htm
  22. 38FLATTIE
    38FLATTIE
    from Colorado
    All Caddy flatheads were hydraulic, and I thought Ford and Merc had some too! Could be wrong about the Ford/Merc.....
    And you can make a LOT of the speed parts yourself, or get a HAMBer to do them
  23. scootermcrad
    scootermcrad
  24. nexxussian
    nexxussian
    Wow, 3 year old post.:eek:
    As I understand it the 8EL (Lincoln) had hyd tappets where the 8EQ (truck) had solids, or so I read.
    There's a guy in Oregon that makes stuff for the both the Lincoln V8 and the V12.
    Bring $$$$, none of it's cheap.
  25. Here is my 337 before I pulled it and put a lighter 500 Caddy in.
  26. notrod13
    notrod13
    from long beach
    oops you meant v 8 sorry
  27. I´m planning to run 337 first with original equipment and when eweryhting else is breaked in with the new car , i start to make my own speedparts for that big´n heavy motor.
    Intake is cast iron piece that can be made from aluminiun , save veight allso , exthaus manifolds i take out right away , because they don´t fit the 32 framerails. I will make Zoomies to exhale. The engine was already on the ch***is ,and it looked pretty cool to me.
  28. johnny bondo
    johnny bondo
    from illinois
    looks like an 8ba to me....=/
  29. chucklz
    chucklz
    from KC
  30. Tank
    Tank
    Look where the distributor is though.
