Technical lincoln front brakes
Discussion in 'Traditional Hot Rods' started by sfowler, Feb 13, 2019.
  1. sfowler
    sfowler
    I,M LOOKING FOR INFO ON INSTALLING LINCOLN BRAKES ON MY MODEL A-V8 WITH A 32 FRONT AXLE AND 40 SPINDLES . THE 1939 THRU 1948 SEEM TO BE WHAT EVERY ONE USES . I HAVE FOUND A COMPLETE SET FOR A 1949 INCLUDING DRUMS , SPINDLES , HUBS , AND ALL . I BELIEVE THEY ARE STILL 5 ON 5.5 BOLT CIRCLE . HAS ANYONE SEEN THESE USED BEFORE . I WOULD LIKE TO RUN 1935 WIRE WHEELS. THANK FOR ANY HELP . STEVE
  2. 100% Matt
    100% Matt
    Steve you'll need to remove some material on the top of the spindles to fit the Lincoln backing plate. The bolt pattern is indeed 5 on 5.5" . Its a common application for better braking
    However I’m not sure about 49 backing plates as 39-48 are the preferred years
  3. alchemy
    alchemy
    I bet a 49 Lincoln was an independent front suspension, and the brake's mounting surface was different than the straight axle cars. Might not fit on 40 spindles without a bit of fabrication. Or might not fit at all.
  4. 48stude
    48stude
  5. seb fontana
    seb fontana
    from ct
    Since Jamco lists coil springs for the front of a '49 Lic I would have to say it has independent front suspension; something in my memory bank says it used the Merc frame..Nothing is probably a direct bolt on..
  6. 8dearborns
    8dearborns
    39 Lincoln brakes are unique and are very deep bolting on to 32 Ford spindles. I like them because they place the front wheels in their exact position as they are on a stock 32 Ford. 40-41 Lincoln brakes have flatter backing plates like 40 Ford brakes and are interchangeable. They bolt on to 40 Ford type spindles..
    The 46-48 Lincoln brakes are different with different spacing altogether. 49 and later are from a different planet.
  7. Jalopy Joker
    Jalopy Joker
    ls1yj and jebbesen like this.
  8. goldmountain
    goldmountain
    I know nothing about Lincoln brakes. However, I do remember magazine articles. In Toddler's Journal #78, regarding the Gray Baskerville car, it says it has 1952 Lincoln brakes in the front as well as a rear axle from the same car. In the picture, it looks like the same brakes as the earlier cars.
    Sent from my SM-T350 using The H.A.M.B. mobile app
  9. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    48 would work but 49 will not- totally different spindle mount and offset.
    There are 3 different styles of 39-48 brakes and they have to do with the depth of the offset of the plate.
    I used 47/8 Lincoln plates on my roadster and made 1/2 spacers for the backing plates. The rear brakes require no spacer and you can fill the brake cable hole and run them in the front they look just like 39 plates.
    39 required no spacer and the inbetween year 40-? had a deeper offset I think... I can’t recall.
    They will all bolt right up to your 40 spindle!
    jimgoetz likes this.
  10. BamaMav
    BamaMav
    from Berry, AL
    1949 was a totally new ch***is design for Lincoln. IFS, open drive rear.
  11. 19Fordy
    19Fordy
    If you want to install Lincoln brakes on 40 Ford spindles the stock 49' Lincoln brakes will not work.
    49-51 Merc. brakes are 11 in. I think 49-51 Lincoln are also. You need the Bolling Bros. 12 in. brake set up.
  12. manyolcars
    manyolcars
  13. manyolcars
    manyolcars
    Bolling Brothers does not include the self adjusters
  14. goldmountain
    goldmountain
    We all agreed that 1949 they went IFS, but who really has first hand I information as to their brakes? Where are those Mexican Road Race guys?
  15. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    King pin inclination, king pin length and diameter would come into play.
    To change the inclination you would need to do that on the axle using a jig-
    You might need to change the bore of the axle or the spindle depending on bore.
    Is there enough height/room for the axle between mounting holes? Maybe spacers? Maybe trim axle a tad?
    Photos would help- have any?
    Measurements would help.
    Anyone know what kingpin inclination is on 49 spindles?
  16. goldmountain
    goldmountain
    I re-read the initial question where he said it included the spindles and of course, the spindles won't work but the brakes might. I mentioned that the Rodder's Journal article said that Gray Baskerville's roadster had '52 Lincoln brakes. In the August 1972 Rod & Custom, Gray Baskerville himself says that they are '52 Lincoln. The April 1990 issue says they are '56 Lincoln. In any case, definitely the IFS era. My point is, if the backing plate has a big hole in the middle surrounded by 4 in a square pattern like early Ford, they should work. Scan-190217-0001.jpg
