Technical Lincoln handy mig trouble
Discussion in 'The Hokey Ass Message Board' started by chop777, May 15, 2014.
  1. chop777
    chop777
    Hello all can anyone answer this question?
    Have a 115 Lincoln handy mig welder
    About 8 yrs old ...just yesterday it stopped feeding wire on the low settings
    But works fine on high settings
    What gives?
  2. tenfive0
    tenfive0
    Do you have power on the low setting? Take the contact tip off and see if you can strike an arc. Could be your rotary switch is burned out on the lower settings. Where are you located at? I use a good welder repair shop in my area when my welders go on the frits and I can't figure out what is worng.
  3. chop777
    chop777
    I'll check for arc with the tip off
    On low setting (not rotary one high /low and one 1/2 switches...)
    Makes a definite click when you pull trigger but wire doesn't feed
    Flip the switch to high / 1 or 2
    Works like a charm ...
    Guess it could be the low switch?
  4. TwoLaneBlacktop
    TwoLaneBlacktop
    from Burien
    Is there a drive wheel adjustment for the wire on your machine? On my Lincoln I was having the same sort of issue and it was just a small adjustment to the tensioner and all was well again.
  5. tenfive0
    tenfive0
    If you have the tip off it should arc not just click. If you can get to the back of the rotary switch take a look at it because it could show signs of being burnt if the switch is bad on the low side. Sorry I'm not familiar with Lincoln Welders and I can't offer any advise on how to take it apart. I have a Miller 252 and a Hobart Handler 140
  6. rockable
    rockable
    Could be that the potentiometer that you use to adjust wire feed with needs either cleaning or replacing. Use an ohmmeter and check it out.
  7. daliant
    daliant
    Maybe cycle the switch a few times back and forth, it might not be making good contact internally. My little Lincoln wont feed if the heat switch is slightly off the detent between ranges. Try holding the trigger and rock the heat switch around.
  8. chop777
    chop777
    OK so on low 1 or 2 there is no power to the lead....I tried to rock the switch while holding trigger nothing......what else
  9. chop777
    chop777
    There is a audible click ...like a relay when I pull the trigger .....but no juice
  10. tenfive0
    tenfive0
    It appears you blew a smoke seal on the rotary switch. If you open the cover to see the back of the switch you'll see where the seal failed and where the switch is toasted. More then just a drive problem if you have no power at all on the lower settings. On my Hobart it is recommended not to turn the rotary switch power/heat setting while welding.
  11. chop777
    chop777
    It has rocker switches ...only rotary switch is wire speed....
  12. tenfive0
    tenfive0
    Whatever switch rocker or otherwise that controls low 1 or 2 is the switch you want to check. Like I said earlier I'm not familiar with Lincoln Welders.
  13. chop777
    chop777
    Thanks man ...I will get new switch
  14. chop777
    chop777
    Update got a new switch and only still works on high settings...I sold it to a buddy cheap got an Eastwood machine and shielding gas tank....
    Sweetness.....
    Now I can weld a broken heart
