Technical Lincoln overdrive transmission
Discussion in 'The Hokey Ass Message Board' started by EzraB, Jan 9, 2026.
  1. EzraB
    EzraB
    My dad and I have been working on a Model T project and we're running a 40s Lincoln Overdrive. Has anyone ever adapted these Transmissions to a Ford column shift cars.
  2. Pics of trans
  3. EzraB
    EzraB
    I don't have any actual pictures of the actual transmission but this is what it looks like
    LOU WELLS and chryslerfan55 like this.
  4. It’s a side shift
    should be simple to shift on the column.
    chlsnk, LOU WELLS and chryslerfan55 like this.
  5. EzraB
    EzraB
    They're a little different than a Ford side shift and we're trying to put it in a Model a ch***is and it's a very tight space
  6. NoSurf
    NoSurf
    I have one in my AV8 coupe.
    Column shift. AA frame.
    Its awesome for 1/8th mile drags with a flathead. Im running right at 10s flat.
    My coupe at 24:24.
    jet996, Tim, LOU WELLS and 4 others like this.
  7. EzraB
    EzraB
    Do you have any photos of what you did with the ch***is or what you did with the column shift
  8. NoSurf
    NoSurf
    I didnt do anything special. Made a new trans crossmember. Hooked up the trans and adjusted the connecting rods.
  9. EzraB
    EzraB
    Okay
  10. NoSurf
    NoSurf
    Obviously had to shorten the driveshaft and torque tube.
  11. EzraB
    EzraB
    Yeah I know that we have to shorten the torque tube. How long is the wheelbase on your car
  12. Son, you’re gonna drive me to drinkin if you don’t stop driving that hot rod Lincoln.
  13. EzraB
    EzraB
    Lol. I've heard the song. The only bad thing is that we're not running a Lincoln engine
  14. One of those popped up a while back on FB. Almost grabbed it. Then ended up with a 51 merc bell and a ford OD top loader.
  15. NoSurf
    NoSurf
    I stretched my wheelbase to 106".
  16. EzraB
    EzraB
    The wheelbase is a stock Model A on our car because we're using a stock Model A ch***is
    NoSurf likes this.
  17. NoSurf
    NoSurf
  18. 42merc
    42merc
    I put one in a '40 coupe. 13" taken from the driveshaft & torque tube.
    A little bit of fussin', worked well.
  19. Model A Gomez
    Model A Gomez
    I guess they're right that you learn something every day, I never knew that Lincoln had a closed drive line overdrive. Now I wonder if it would bolt to a Ford top loader closed drive transmission. Looking at the back of the case I'm guessing it probably won't but interesting if it would.
  20. EzraB
    EzraB
    You cannot. Without modifications to the transmission housing and they're are closed Drive. The 1949-50 Mercury had the same transmission but with a open Drive
  21. Here’s the merc OD with floor shifter
  22. EzraB
    EzraB
    That looks cool and that would work but the only problem with a Model T is it's a smaller car and the shifter will be over towards the driver more and that's why I want to use a column shift instead of in the floor
    anthony myrick likes this.
  23. I was kicking around using a FH in a model A that I just rounded up. Friend had this OD trans
    from what I read a Jeep T-90 shift tower fits it.
  24. EzraB
    EzraB
    We already have a adapter for the Lincoln transmission. We are running a y block Ford
  25. Yep. This one was born behind a Y
  26. EzraB
    EzraB
    We don't have a original manual bell housing for a Y block and we already have all the parts that we need to use the Lincoln transmission besides the linkage and the hydraulic stuff for the clutch and a solenoid
