Hot Rods lincoln v12 starter
Discussion in 'The Hokey Ass Message Board' started by cshades, Jun 17, 2025.
  1. cshades
    cshades
    from wi
    i have a 1946 lincoln in the shop. it is throwing sparks out of the starter. the customer wants it changed out. the car was converted to 12 volts 15 years ago so i was thinking of a power master starter for it. is the v8 flathead starter the same as the v12 flathead? i dont do a lot of flathead stuff but i am sure you guys have. thanks for the help.
  2. 51504bat
    51504bat
    Don't know if the V8 and V12 use the same stater but I'd run away from an original style Powermaster starter. They look and fit just like an original but when you pull it apart (after it dies) the actual working parts are about have the size of the case. POS IMO. Don't know anything about the Powermaster gear reduction starters.
  3. fordpatina
    fordpatina
    The V8 flathead starters works with with 1936-48 lincoln zephyr V12 Engines
  4. cshades
    cshades
    from wi
    thank you fordpatina. thought so but needed a real answer
