Lincoln V12 transmission???
Discussion in 'The Hokey Ass Message Board' started by dsiddons, May 26, 2011.
  1. dsiddons
    dsiddons
    from Indiana
    Tossing around building up a Lincoln V12. What ****** option will I have? Say it's a 41' Motor? Seems like most of the stuff I run across doesn't have a transmission with it.
  2. MeanGene427
    MeanGene427
    from Napa
    I have a complete '46 with the OD trans still on it, and enough parts for most of a second one, plus axles, wheels, lotsa stuff- getting it to where you live could be a beyotch, however
  3. resqd37Zep
    resqd37Zep
    from Nor Cal
    Anything that can bolt up to Flat 8 will mate to the Lincoln V-12. Back of the block is all the same. I had one in a 37 Lincoln with a t5 speed. Cornhuskers makes several adapter options.
  4. dsiddons
    dsiddons
    from Indiana
    Thanks for the info...
  5. dsiddons
    dsiddons
    from Indiana
    Napa? In California? Yeah, that would be a haul.. Sounds like good stuff thou..
  6. Dale Fairfax
    Dale Fairfax
    Where in Indiana are you? I have a Lincoln O.D. in pieces-it's somewhere between '41 and '48; side shift. All there but needs ***embly. Cheap.
  7. Crestliner
    Crestliner
    I have a complete 47 O.D in very good condtion.
  8. dsiddons
    dsiddons
    from Indiana
    You always got good stuff.. Is that a sideshift?
  9. fastbrad
    fastbrad
    I'm looking for a trans for my '41 V12 too... resqd37Zep, you mention that anything that will bolt up to the 8 will fit. I was just talking with a guy with a '51 3 speed, and he thought that early (32-48) and late (49-53) were different--is that correct?
    -Brad
  10. Dale Fairfax
    Dale Fairfax
    He meant to say: Anything that bolts up to a '32-'48 Ford/Merc will bolt up to the v-12. Everything after '49 (except '49--'50 Merc) is a no go without adapters.
  11. fleetbob50
    fleetbob50
    from Waco,Texas
    IT WILL BOLT DIRECT TO THE LATER CAST ENGINE TO TRANS ADAPTER AS WELL
  12. fastbrad
    fastbrad
    Ok, thanks very much. Now I know exactly what I'm looking for.
    Brad
