Hot Rods Lincoln Y-Block Identification
Discussion in 'The Hokey Ass Message Board' started by Fabber McGee, Nov 2, 2014.
  1. Fabber McGee
    Fabber McGee
    I came across a mid 50's Ford truck with a Y-block. I didn't notice the badge number (F-5, F-4 etc.), but it has the big 6 bolt dual wheels. The exhaust has a top front crossover pipe and I read sometime that the Lincoln engine usually had rams horn exhaust manifolds. Is there a quick way to tell a Lincoln engine from a p***enger engine without s****ing around for numbers and such? Something simple like the distance between exhaust manifold bolts, etc. It seems quite possible to me that someone changed from the original engine over the years and I'd like to know what this one is.
  2. RichFox
    RichFox
    The y block Ford has the stacked intake ports. Easy to spot. The Lincoln is more conventional.
  3. If it has the large 6 bolt pattern with 20 inch tires it is a '56 & up F600,,,probably a 272.
  4. RichFox
    RichFox
    The length of the Lincoln valve cover is roughly 18 3/4 end to end on top. 20 1/2 measuring the flange that sits on the head.
  5. RichFox
    RichFox
    14 inches between valve cover studs.
  6. Fabber McGee
    Fabber McGee
    Okay, thanks guys. I'll be seeing it again tomorrow, I'll check it out.
  7. rob lee
    rob lee
    from omaha,ne
    The bolts on the exhaust manifold on a ford y re all in a line and on the lincoln y the 2 end bolts sit higher. Pretty easy way to tell.
  8. RichFox
    RichFox
    Yeah. One in the middle that is also higher.
  9. ,,,,and,,,,,whered' he go,,,,?
