Technical Line lock for hill holding
Discussion in 'The Hokey Ass Message Board' started by blowby, Nov 24, 2019.
  1. blowby
    blowby
    from Nicasio Ca
    What is the preference for a line lock for hill holding, front or rear brakes? Not intended for overnight parking, just stop and go stuff.
  2. Blacktop VooDoo
    Blacktop VooDoo
    It can work on either front or rear for your intended purpose. It operates as a momentary switch.
  3. jaw22w
    jaw22w
    from Indiana
    Put it on the front. Great for burnouts.
    Tickety Boo, HSF and Texas Webb like this.
  4. Put it in the front.
    That’s gonna let you do more than hold a hill
  5. J. A. Miller
    J. A. Miller
    from Central NY
    Yep, lock the fronts - fry the rears!
    pirate and loudbang like this.
  6. rztrike
    rztrike
    Wouldn't this depend on the car as it comes to weight and balance. If its a light front end car it won't matter how big the brakes are up front the locked wheels will slide. I guess size of the hill needs to be taken into consideration also. To many variables and I feel that I'm overthinking it today. Sorry
  7. BamaMav
    BamaMav
    from Berry, AL
    Right. Might not work too good on a T bucket with wire front wheels, 4" wide tires, and Mickey Thompson Sportsmans on the back......
  8. blowby
    blowby
    from Nicasio Ca
    Or at a stop light on a steep wet hill maybe.
    gimpyshotrods and loudbang like this.
  9. theHIGHLANDER
    theHIGHLANDER
    For most generic apps I'd think front would do. That's where the motor is so that's where the weight is too, right? In that same situation I grab the hand brake to transition from stop to go but that dictates a pretty torquey engine that's able and a few seconds of clutch slip. I mean, a Line-Loc switch on a Packard or Duesy would be a little outta place, no?;)
  10. jnaki
    jnaki
    Hey B,
    Save your money and I am sure you already know how to do a “hill start” with the clutch, brake pedal emergency lever, and throttle. After learning that method, there is no additional thing (something else as an accessory to go wrong) necessary on any stick shift car. That is why a car length or two behind a stick shift car on those small hills or big hills is necessary for keeping sane while driving. No rollbacks when the light turns green.
    When we were twenty somethings, my wife wanted a stick shift car. We drove all kinds of 3 and 4 speed cars, hot rods, and sporty cars. She knew it got better gas mileage with the stick shift over an automatic transmission. Over the years, she stayed away from the manual transmission cars. She had a bad experience being yelled at by her un-supportive and quick-tempered dad trying to learn the aspects of driving a stick shift car.
    But, she still wanted a stick shift car. She said I could teach her to drive one of those. She had the utmost confidence in me and it was a challenge I could not mess up or else... So, we actually bought a 5 speed sporty car that she had always wanted, but it was always out of reach. Since it was sitting in our carport, she wanted to drive it, right now.
    Driving over to an nearby industrial tract of buildings, after 4 pm during the summer, was a perfect place to learn the finer aspects of stick shift driving. She learned fast and it was fun driving all around the newly created Irvine Industrial tract, just off of the 405 freeway. The freeway lent itself to shifting on the on ramps and merging, but there were a few off ramps that gave her some slippage on starting from the stop sign.
    So, back to the industrial complex to find that small hill with a right turn to practice. We had many practice runs on flat ground going over the "hill start" method of steps. She had a great memory and had the steps down pat. Now, that little right hand corner with a slight grade and stop sign gave us trouble the first three times, but on the 4th, the method was perfectly done. It felt like an automatic transmission car stopping and then proceeding past the stop sign. It does not matter the size of the hill, the cars will all roll back. Unless the hill start method is used in any stick shift car. No other accessory needed.
    Jnaki
    So, what does a happy husband do for his fast learning wife? Why a +1000 mile drive up Highway 1 all along the West Coast to San Francisco, the ultimate test of steep hill stops and starts.
    The pre-test popped up sooner that we liked. In Morro Bay, there is this one corner that has a red stop sign. It is at the end of a short uphill rise, but also stops on an off camber slope. With several anxious driver tailgating behind, my wife calmly put it in first gear and stepped on the brake. She got all of her test information on the hill starts in the forefront and proceeded to do the best stick shift hill start, ever! All with a smile on her face and afterwards, a comment of “… that #$@%& tailgater…”
    San Francisco Golden Gate Bridge …
    An unusual “11-1” death grip, that was “not” in the curriculum! WHAT?????
    https://www.jalopyjournal.com/forum...ers-how-to-drive.1158263/page-3#post-13212425
  11. greybeard360
    greybeard360
    If just for hill holding apply all 4 wheels at one time. Split system would require 2 solenoids.
  12. warbird1
    warbird1
    As an aside, some older Subaru's had hill-holders as standard equipment on stick shift models. Consisted of a valve in the brake circuit set on an incline so an internal ball would roll back and block the circuit if you were on a hill with the clutch depressed. When you started to release the clutch a cable connected to the clutch pedal would actuate a lever on the valve pushing the ball forward and unblocking the circuit. Worked well and was very simple...
    loudbang, harpo1313 and jnaki like this.
  13. King ford
    King ford
    from 08302
    If I'm not mistaken Studebaker had a hill holder in the late fourties...whena saw that Subaru commercial about the " ingenious hill holder clutch I holler'd at the tv! " STUDEBAKER BEAT YOU TO IT !!!
    egads and loudbang like this.
  14. studebakerjoe
    studebakerjoe
    Yep, Studebaker had hill holder. Works really well in my experience. Once you stop on the hill it will sit there when you take your foot off the brake.
  15. 302GMC
    302GMC
    from Idaho
    Quite a few makes offered the hill holder, but other than on Studebakers it's very seldom seen. There's a '46 Chev 4dr here in town so equipped, still working, and never been opened up ...
  16. blowby
    blowby
    from Nicasio Ca
    Ah that's the answer, I need a Studebaker! Cool!
    I don't need it for hill starts, although it sounds handy. The manual gate on my little 7 acres of paradise is on a slope, as is my parking area and the driveway where I sometimes stop to pick up or drop off stuff. My parking brake works ok forward, less so rolling backwards, plus I feel like I'm wearing it out.
    The line lock is on it's way, I presumed I'd put it in front where they normally go, then got to thinking it could just as well go to the rears.
    Thanks for all the replies.
    loudbang and rudestude like this.
  17. dirty old man
    dirty old man
    I use one on my Hiboy roadster on the front wheels and like it a lot. Plan to put one on my '40 Ford coupe sooner or later. I have found that with self energizing drum brakes you need to apply some additional pedal pressure sometimes to keep the car from rolling back if you stopped sorta "gently". This is because self energizing drum brakes utilize the vehicle's forward motion to help put pressure on the brake shoes, and if you are on a steep uphill when you stop, the car may roll back slowly if you don't put a little extra pressure on the pedal after you stop and before activating line lock. I also wait till just before time to start off to apply the line lock in order to not overheat the solenoid in the line lock.
    When I took my driving test back in '52, most cars had manual trans. and the GA State Patrol did the license tests. Locally the GSP station had a nearby steep hill where they had you stop halfway up, and cut off engine, restart, and pull off up the hill! This was the las tpart of driving test and if you had done all the rest OK and then did OK on this, you p***ed.
    As for the ***holes that pull right up behind you when you're stopped on an upgrade, most just never drove a manual shift, and don't know any better. In earlier years, people knew to allow a little extra space on a stop on an upgrade.
  18. wvenfield
    wvenfield
    Seems to me it would be easier to fix the parking brake.
    gnichols, G-son, clem and 3 others like this.
  19. TrailerTrashToo
    TrailerTrashToo
    On most drum brake rear axles, the parking brake does not hold well in the reverse direction - something about applying pressure on only one shoe (on each side).
  20. wvenfield
    wvenfield
    A parking brake in good working order should work in either direction.
  21. TagMan
    TagMan
    I've got a NOS Chevrolet accessory hill holder from the late-'30's. I'll have to dig it out nd post a pic of it. Meanwhile, here's a copy of the installation instructions from it......
    [​IMG]No-Rol Device by TagMan, on Flickr
    302GMC and loudbang like this.
  22. pirate
    pirate
    from Alabama
    Well I don’t have a line lock but this is what I did. I have a small ball valve plumbed into the brake line going to the rear wheels. When I press down on the brake pedal I then turn the ball valve to the off position. This locks the pressure into the line and clamps the brake calipers. Simply turning the valve open unclamps the calipers. In my application I really didn’t have room for an emergency brake. This set up holds car on hills, can be used to hold car on hill with out having to slip clutch while starting up. An added benefit is it can also be used as a security device locking rear wheels while away from the car.
    loudbang, Montana1 and wvenfield like this.
  23. loudbang likes this.
  24. 46fatford
    46fatford
    **** Brannan used a modified Studebaker Hill Holder on his drag cars. The first use of a Line Lock in drag racing.
  25. oldolds
    oldolds
  26. TrailerTrashToo
    TrailerTrashToo
    Must be driving badly adjusted brakes since the early 1960's. My experience is the parking brake can be overpowered easier in reverse. In the forward direction, the self-actuation kicks in. Any one out there have any input?
  27. F-ONE
    F-ONE
    from Alabama
    I can’t help that my opinion is contrary to the concept.
    My newer off topic straight shift vehicle has a factory hill holding type of device.
    It’s made for someone that does not know how to drive a straight shift. I have found it’s a detriment to the driving experience rather than an attribute. It adds to the complexity of day to day driving....When you need to go, you got to fight the dang hill hold. On a hill, it still releases after it holds for several seconds so there’s still feathering the clutch.....
    I find it a bother and I wish the Jeep did not have that feature. There’s no way I would add such to an older car.
    Your results may vary.
  28. rudestude
    rudestude
    I just pulled the hill holder setup off of one of my Studebakers, 50 Champion 4dr. , its a parts car for my 50 Champion Starlight coupe .
    I keep it a driver , easier to move around, but the master cylinder started leaking so I just swapped it for a standard one I had ...brakes work again.
    So here you go , just needs a rebuild... 1574654928160.jpeg 1574655020944~2.jpeg 1574655125093~2.jpeg
    Sent from my SM-T387V using The H.A.M.B. mobile app
    31Vicky with a hemi and loudbang like this.
  29. 57 Fargo
    57 Fargo
    Servo acting drum brakes is one shoe applying force to the other, dual servo is this happens in both directions. These brakes have a shorter primary shoe and a longer secondary. When applied the primary shoe “wraps” into the drum and applies force to the secondary which does most of the work. In reverse the same thing happens only the shorter shoe is trying to do the work. The primary shoe is generally “grabbier” which allows it to apply more force to the secondary. In reverse they don’t apply as well. The park brake applies both shoes on both sides, it doesn’t work as well in reverse because of the difference in shoes.
  30. TrailerTrashToo
    TrailerTrashToo
    Thanks for the explanation. I have read this before, but, could not describe the details after after this many years.
