Line Lock ROll Control Help
Discussion in 'The Hokey Ass Message Board' started by porkchop4464, Feb 17, 2013.
  1. porkchop4464
    porkchop4464
    Hey all.
    Thinking of doing line locks on my car towards the end as I get closer to finished. Never installed one. I also saw in Speedway and another site on Ebay, a button that you can mount and you push down like an inch and it locks (fluid pressure MANUAL)which ever line (set of brakes) you place it on, then the directions state you just tap the brakes and it pops off. That button costs 25 where as teh roll control electric unit seems to run 60. Advice? Install issues?
    Pork
  2. chasracer54
    chasracer54
    What's your intention for the roll control - burnouts or a temporary parking brake?
    <object style="position:absolute;z-index:1000" type="application/x-dgnria" id="plugin0" height="0" width="0">
    </object>
  3. porkchop4464
    porkchop4464
    front wheel lock burnout control
  4. chasracer54
    chasracer54
    You're not going to like that Speedway one for that if I am looking at the right one called a Park-lok? Jegs sells the regular line-lock in their brand for $40, we use it on our Camaro and I have one on my dragster. Nice unit, easy to hook up and install. I don't think it comes with a button so that's something you have to add to the deal. Assuming you have a dual master, come off of the front brake port to the inlet of the line-lock and then from the output of it to the front brakes. Connect power through a momentary button and your done. Enjoy the smoke!
    </object>
  5. porkchop4464
    porkchop4464
    Dual Master! Man,
    I have a single pot, 61 Chevy clutch/brake, Milner master. I assume that does cause an issue. Man, I can't win for loozin this month.
  6. porkchop4464
    porkchop4464
    Boom! I'm not trying anything here, really!
  7. your roll control has to be spliced into the frt brk line with the button mounted on thr shifter or steering you have to apply the brakes and hold the button down to lock the brakes upon release the brakes are released
  8. PKap
    PKap
    from Alberta
    You can plumb the solenoid into your main front brake line regardless of your master. I would use the Jegs unit as that is what it is designed for. Easy installation.
  9. black 62
    black 62
    from arkansas
    don't use the electric one for a parking brake....
  10. yellow dog
    yellow dog
    from san diego
    If you care NHRA rules says that all line locs must be self-returning to normal brake operating mode. You interpret as you like, but I don't think tapping the brake pedal as self-returning.
  11. SinisterCustom
    SinisterCustom
  12. 61falcon
    61falcon
    i have a line lock on my Falcon for getting the drag radials warm at the track. easy install. i have a Hurst shifter with button built in for activating the solenoid. it also comes in handy when sitting at a traffic light on a hill.
  13. porkchop4464
    porkchop4464
    thanks guys, seems the electronic seems best, but that large dash lever one seems tuff as hell. Pork
  14. captmullette
    captmullette
    got mine from summit $40 added a toggle works great easy install.
  15. kennb
    kennb
    Yeah, that dash lever should look cool for $380. Ken
  16. porkchop4464
    porkchop4464
    Yeah, I hear you KB. Why does the cooler looking stuff always seem to cost the damn most in life? Seems like the cheapy Zegs elec roll control is the best for me,
    As usual, thanx for all the great details, folks.
    Pork
