linear actuator wiring
Discussion in 'The Hokey Ass Message Board' started by pastorbc, Dec 6, 2012.
  1. pastorbc
    pastorbc
    from kentucky
    any fellow Hambers worked with 5 wire linear actuators? I know the blue & green are up/down, but what about the smaller black, red & yellow? I'm using these to raise/lower the hood on my 55 f100. thanks, Bob
  2. FrozenMerc
    FrozenMerc
    Normally the extra wires are for a feedback loop, so a controller knows the position of the actuator. They will give position of the actuator by a changing voltage output. Typically, Red is +5 or +12 V, Black is ground, and Yellow is the signal (0-5 V or 0-12 V).
  3. Dane
    Dane
    from Soquel, CA
  4. chaos10meter
    chaos10meter
    from PA.
    You don't have to get real fancy or need a degree in Electrial Engineering.
    I just used a 6 pole , on/ off / on momentary rocker switch, for the hood and the trunk of a 48Chev Aero Cp.
    Wired it like shown.
    Just have to make 2 jumper wires , and pig tail them to two poles going to actuator. in other words the switch shown is wired ,now you have to tie it into the actuator wires just make a jumper from one of the black and one of the red right to the actuator wires.
  5. Ask this guy..........
  6. pastorbc
    pastorbc
    from kentucky
    thanks for the help. does the black wire need to be grounded, or does the unit ground itself? it doesn't seem heavy enough for a ground. thanks again, Bob
  7. chaos10meter
    chaos10meter
    from PA.
    I didn't gound the switch itself, if that answers your question ?
  8. pastorbc
    pastorbc
    from kentucky
    thanks for the reply. I was actually wondering about the small black wire on the actuator. thanks, Bob
