Links to Holley 94 Technical info
Discussion in 'The Hokey Ass Message Board' started by Dreddybear, Aug 14, 2008.
  1. scootermcrad
    scootermcrad
    AWESOME! I'm workin' on a banner for you right now...
  2. Dreddybear
    Dreddybear
    Muchos Gracias Amigo. I have my scepter ready :D
  3. Dreddybear
    Dreddybear
    Back up, I've added several really good discussions...
  4. 50shoe
    50shoe
    Stogy likes this.
  5. Dreddybear
    Dreddybear
    Way ahead of you brother! That's an excellent article. One of the first links up here. Thanks for lookin out!
  6. kevinc
    kevinc
    from highland
    awesome gona save this thread, i want to run a couple on my 270 gmc, just gotta find a couple. thanks for the info
  7. Dreddybear
    Dreddybear
    There is now a group dedicated to 94's. You can view it's contents and join HERE
  8. scootermcrad
    scootermcrad
    Thanks Paulie!
    BTW... need to chat with you about this very subject! I'll get with you in a PM later when we have a little more time.
  9. Dreddybear
    Dreddybear
    I've added a ton of links to this page as well as the social group page. Here it is for those who may need it. :)
  10. scootermcrad
    scootermcrad
    Awesome!!! Thanks man!
  11. Flingdingo
    Flingdingo
    Bump. I was searching for 94 info and found this thread...12 PAGES IN!!!!
    Thanks Dreddybear for compiling this.
  12. mullskull
    mullskull
    this thread is like finding a vain of gold!
    thanks for the effort!
  13. Rehpotsirhcj
    Rehpotsirhcj
    x2
    Thanks a ton.
  14. Donnj
    Donnj
    from North NJ
    Rebuilding some 94s and got the kit from Vintage Speed and was wondering if anyone had any pics of the torsion return spring installed on a 94
  15. oj
    oj
    The spring isn't on the throttle shaft, it is situated on its' own boss and behind the link bar for the choke. The throttle shaft has no spring that i have seen. My pics aren't the best but i think you can see what is going on.
  16. Donnj
    Donnj
    from North NJ
    Thanks OJ great info, the springs im trying to install are called throttle base torsion return springs from Vintage Speed which didnt come on my carbs originally. These springs are to eliminate one large throttle return spring. thanks
  17. Dreddybear
    Dreddybear
    I like the idea of those, especially on multi carb setups where sometimes it's hard to get one spring to get all the carbs closed that last 1% that gives you an idle..
  18. oj
    oj
    Do they go on the throttle shaft? Problem with that is that the throttle shafts are soft br*** so try to configure things so that they aren't under tension. The throttle arm (to the carb) is the safest place to have the spring so that the tension is on the pedal not the carb.
  19. Donnj
    Donnj
    from North NJ
    Me too Bear, not to mention it looks alot cleaner than a big spring, just cant seem to figure out where the spring mounts
  20. Truckeez
    Truckeez
    Hi I just joined the group--Got a big load of 94s
    a few early ones
    a 92 and a 57
    a bunch of 8ba's and unmarked same
    a couple 1 1/16 venturi
    one holley with bigger throttle bores-marked holley not ford( its got load - matic dashpot.
    and four one barrels
    heres the link for converting a load o matic to newer vac*** advance distributor port http://www.eatonbalancing.com/blog/...ey-94-two-barrel-for-late-model-distributors/
    Question. Early ones only have the two air bleed holes in the top of base.
    the load o matic got the extra hole on the base and the edges are camfered.
    But some of mine that were not load o matic also got the third hole--WHY??
  21. Scooter , on your "build" discuss the drilled hole in the upper housing on some units and also discuss the proper way to color the Holley. Also discuss the "mystery" of using a new style power valve.
    thanks
    working on my 15th one in two months, only 12 to go....
  22. Very helpful Dreaddybear.
  23. forty1fordpickup
    forty1fordpickup
    Here is a shot of the late PV vs a modified one. I ran into this problem myself.
    Stogy likes this.
  24. Dreddybear
    Dreddybear
    BTT sorta, just so folks can find the group..
  25. Dreddybear
    Dreddybear
    I would like to Endorse ****ster27 as my official 94 parts supplier. Also he can build full setups that look beautiful.
    Stogy likes this.
  26. bjinx
    bjinx
    This is a great thread for anyone planning on using 94's in a multiple carb set-up, wealth of info. Shout out to Dreddybear for putting it all together, plus to all who added info to this thread. Happy reading
  27. oldscl
    oldscl
    Glad I came across this. Thanks Dreddybear and contributors. BTTT cause you can never have too much info on these things.
  28. Tim
    Tim
    from KCMO
  29. bjinx
    bjinx
  30. brEad
    brEad
    Bookmarked! Thanks, @Dreddybear for this comprehensive list!
