Technical Lithium Battery Jump Starter
Discussion in 'The Hokey Ass Message Board' started by mwhistle, Nov 14, 2018.
  1. mwhistle
    mwhistle
    from sacramento
    Does anyone have experience with these Lithium Ion battery jump starters that replace the need for jumper cables?
  2. Dick Stevens
    Dick Stevens
    Unless you're goingto use them a lot, I think they are a waste of money. Good set of jumper cables will last forever, but the jump starter won't!
  3. 327Eric
    327Eric
    got one at work, it works well. Don't know how long it will last, but 1 year so far
  4. Ebbsspeed
    Ebbsspeed
    My dad has an older one that charges from 110 VAC rather than being charged from a switched 12 volt circuit in the car. When he needed it, it was plugged in at the house. Get one that stays in your car and charges from a 12 VDC source.
    Don't throw your jumper cables away.
    RMONTY likes this.
  5. noboD
    noboD
    I tried to use my new one on a tractor with a dead battery. It did nothing so I took it back. I was told they will not work with a completely dead battery, needs to have some voltage in it. Did not know that or I might not have bought one. It will power my GPS when in a six volt car or charge a phone.
  6. mwhistle
    mwhistle
    from sacramento
    Will they work with Optima (AGM) style batteries?
  7. injunjoes
    injunjoes
    I have a noco genius and it works well it has saved me several times
    partssaloon likes this.
  8. 28 Ford PU
    28 Ford PU
    from Upstate NY
    I have one in the Hot Rod I use quite a bit but not yet for jumping the battery. It has a couple of USB ports I use to charge my phone which I use a lot for GPS, music (Real Hot Rods don’t have radios), I run a speedometer app cause the old SW 160 is off a bit but that’s ok. Sometime I bring the lap top too.
    lothiandon1940 likes this.
  9. G-son
    G-son
    from Sweden
    Lithium batteries has the ability to supply a suprisingly large current despite being small hand having little capacity. That means when done correctly, such a jump starter should have the ability to do a good job. I don't know if all of them are done correctly…
    Either way, a jump starter needs to be kept charged, and jumper cables needs another car to hook onto. There are no magic solutions that always work. Having a backup option is nice.
    Boneyard51, pitman and lothiandon1940 like this.
  10. RidingMechanic
    RidingMechanic
    from Cincinnati
    Same here. We got one of the 200A Noco models which features the emergency start mode (it deactivates the current sensing software and acts just like a jump box). I pulled the cables completely off a big block chevelle battery and connected it directly to the cables. It started like it was on a fully charged lead battery.
    Downside is that it costs about $200 and doesn't do AGM batteries. Upside is they should hold a charge for months, if not years.
  11. Hotrodmyk
    Hotrodmyk
    I have used them a couple of times to help out friends. They work well in a pinch.
  12. wvenfield
    wvenfield
    Yes, jumper cables still work great. If there is someone around to jump you. I have one and it works really well. I was surprised at how much power they hold. Takes up less room than jumper cables also.
  13. HOTFR8
    HOTFR8
    Watch this >
  14. tubman
    tubman
    That's scary, but what exactly are we seeing? It's not very evident.
  15. lothiandon1940
    lothiandon1940
    Those little Lithium Ion chargers are pretty cool, but any Lithium Ion device I find to be a little scary. Too many hover-boards burning down houses!!!
    G-son likes this.
  16. topher5150
    topher5150
    I saw a guy with one of those jumper packs wedged under his hood driving around town
    Sent from my XT1710-02 using The H.A.M.B. mobile app
  17. lothiandon1940
    lothiandon1940
    .........Scary!
  18. mcmopar
    mcmopar
    from Strum, wi
    I had one that got hot then expanded enough to split the case. Called company they said send it back, but there was nothing wrong with it and it was safe. Got the new one and it did the same thing. I have heard of them starting on fire and after 2 bads, im not leaving one in my car.
    Tony
  19. Truck64
    Truck64
    from Ioway
    Well I wondered about that. They are amazing, but anything the size of a smartphone that can jump off a V8 has to have a lot of potential energy stored.
    What's the backstory on the fire in the servicebay?
  20. partssaloon
    partssaloon
    S**** the thread, not traditional !
    Been using mine for 3 years, works great.
    Truck64 likes this.
  21. Ebbsspeed
    Ebbsspeed
    Doesn't look like the guys in the video were too concerned about breathing the fumes from that burning jumper box. There is some nasty toxic stuff vented when they burn. Don't breathe it if you can avoid it.
  22. Truck64
    Truck64
    from Ioway
    I think those jump boxes are just that, and they were using it to try and charge a dead (or defective) battery? Wonder what the instructions say. (I know, I know, crazy talk)
  23. upspirate
    upspirate
    Real men don't need instructions, educated men read them after they screw up
  24. typo41
    typo41
    Saturday morning at El Mirage and 25 degrees, it took three jump boxes to start the H&H Dodge Omni. What I found was there are difference and charge power. Our Costco one only lasts for 30 seconds, gotta be quick. What we ran into was it would crank, but was short the voltage to fire up the ignition system. Finally a racer brings over an obvious larger batter pack, the early ones were the size of a thick cell phone, his was the size of a paper back and it started it right now. So, like in batteries, look for jump time and cranking amps. And they are easier to carry around than the snake of jumper cables and one of the old yellow HR jump boxes.
  25. dirty old man
    dirty old man
    Fellow club member had one that came close to setting his attached carport on fire while it was sitting on a shelf and plugged in 120V outlet to charge it up.
    I have one also, was a Father's day gift from son a few years ago, but since Ed's near disaster, I make sure it's setting on a non flammable surface when I'm charging it.
  26. pitman
    pitman
    Earlier batt. Configurations were Ni-Metal-Hydride. Lithium-Ion is the newest form.
    They typ. have even higher current density.
    So they will, when high current demand appears, get 'warm'. Internal cell loss (a % factor) causes the heat generation. Advice I've read says; keep them charged at 95+ %.
    Suspect, that if the 'package' design shrinks, as in barely able to match the power-load, you'd be up against the limits.
  27. HOTFR8
    HOTFR8
    That is what happens when you leave them. They catch fire. I have heard of them failing sitting on the shelf.
  28. jimmy six
    jimmy six
    We used the air compressor included at our dirt track, it lasted for 5 yrs. Never charged over 1 HR. After I removed the compressor part I put in a larger battery... Works just as a jumper now. I still carry cables in the trunk of my 56.
  29. jazz1
    jazz1
    I have the Genius GB40. Use it quite often as I have lame batteries in my tractors. I used it on my hotrod to boost. Worked good so I disconnected battery and started truck and ran it without battery for a day just because we know sometimes you can't boost a bad battery.
    These units are idiot proofed however there is a override switch.:D
  30. junkyardjeff
    junkyardjeff
    I bought one from the tool guy who comes to work and mainly use it for charging cameras and other small devices and take it along on trips,its started a few cars and and tractors during the two years I had it.
