I'm in the process of setting up the rear suspension on my '33 fenderless pickup. I would like to use these mono springs I have in a parallel setup. The springs are 2" wide 7/16" at the thickest point and are 42" long. They were removed from I think a Geo or some other fwd compact. (I used the axle to get my cement mixer rolling). I can stand on these springs and they flex considerably. I'm thinking they would offer a pretty cushy ride if they would hold up OK and not break or something. Also, thinking I could add a leaf or two in the future if they seemed too soft. Thanks for all response. Facts to consider: rear of frame is boxed W/ 1/4" plate 17g. fuel tank radiator in bed Ford 8.8 Flathead power
I think your gonna need some type of torque arm, a mono leaf in a parallel set up is gonna have alot of spring wrap, especially something that soft. If it doesnt work well it would be easy enough to swap in a different set of springs though.
