Hot Rods LIVE WIRE gets a transplant: Rebuild thread
Discussion in 'The Hokey Ass Message Board' started by Evel, Mar 4, 2012.
  1. FYI, this is a closed drive set-up in this picture.
  2. Nice to see ur going to get it going again. Maybe lsru '13?
    Sent from my iPhone using TJJ
  3. flt-blk
    flt-blk
    from IL
    I still have the Roadster getting married and moving to Chicago I'm not sure an open car is for me right now.
    Good luck updating the coupe.
  4. general gow
    general gow
    MODERATOR
    woohoo! stoked to see it happen.
  5. Evel
    Evel
    Yes thats the route I would of gone if I didn't get such a great deal on this stuff...
    I have enough to make it work its close... Lomas is running the short shaft and Ford open drive set up... and any thing he does is right.. hahahaha Gonna talk to him... Do you have his # PM' me if you do..
    The tunnle needs to get re done cause it HUGE.. the LaSalle is allot smaller so its gonna have to get done.... I just did some measuring the Stock mount on the La Salle (short tailshaft) is pretty close to the Stock Hydro witch if I went this route I wouldn't have to mess to much with the cross member...
    I'll have some thinking and decisions to make once that car is all apart... STAY TUNED...
  6. Evel
    Evel
    MAybe??? :D
  7. Evel
    Evel
    Are you offering back to me? Damit!!! hahahahaha
    As much as I want it back for sentemental reasons I gotta build the A insted.. :(
  8. Makes sense, Lomas got the open drive for the quick change.
    Ask Rudi he's got his #.
    Just wondering, since I'm not familiar with the Lasalle, is it 3 speed also and heavy-dutier than the Fords?
    If you change everything to Ford, you easily spend $1200 for all the parts, totally makes sense to stay with what you've got.
  9. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    It's a 3 spd and has an even beefier main cluster shaft then a Lincoln trans. IF you ever compare the LaSalle and the Early Ford trans you can clearly see just how stout the LaSalle is and why it was chosen for drag racing duties along with the similar Buick and Packard trans'.
  10. Evel
    Evel
    Yeah the Ford swap would of been cool.. but finding the Stick bell housing etc.. thats what rules cause theres no adpters.. everything should just fit...
  11. Evel
    Evel
    I'll probally run one behind the Nailhead when I build my roadster some day..
  12. Dreddybear
    Dreddybear
    Dude, glad to see this happening!
  13. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
  14. Cool, I didn't know there is no adaptors for the Ford-Cadillac set-up.
  15. TexasSpeed
    TexasSpeed
    from Texas
    Happens to the best of us.;) I'm glad to see this is getting three pedals! I'll be watching this..
  16. Evel
    Evel
    No there are Caddy to Ford adaptors.. I would of had to buy one of those on top of the buying the toplaoder.. thats what I ment :D
  17. jick
    jick
    from london
    this is going to be a very interesting thread....although maybe I shouldnt be reading it,
    bearing in mind i'm right in the middle of setting up my ch***is for my 331 & hydramatic....
    you can all say " i told you so" later on down the line....
  18. Evel
    Evel
    Jick... don't do it.. But if you do and you need a nicely rebuilt low milage hydro i'll have one for sale :D
  19. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    This is gonna be fun to watch!
  20. SteadyT
    SteadyT
    **** and YES.
    Will the video camera be out during all this? :D
  21. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    SOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
    dose this mean your actualy gona drive it?
  22. Noland
    Noland
    thats what you get for putting automatic in it. Glad to see this happening. just what live wire needs. I started building my 1st coupe with a hydro, jetaway behind a 390. different but the same. the car didnt even come close to making it on the road before I changed it to a 4 speed. automatics are lame in hotrods. Good luck Ill be watching
  23. jick
    jick
    from london
    one carefull old lady owner yeah? :D
    I will probably live to regret it, but i KNOW mine was working great in the car it came out of.....i'd much prefer a manual but if its tricky for you to turn up the right parts over there with your connections it would be almost impossible for me here in London....i gotta work with what i've got!
    and i'm with you on the 700r4 / T-5 scenario...
    ( oh...i'm after some nice original chromed headers for my 331....any leads?;))
    cheers...Jick
  24. Evel
    Evel
    As long as you have all the linkage to the carb dialed in your good.. but once you start swapping intakes and channeleing the car it gets tricky.. I'm sure theres ways to make it work great and believe me I heard every story on how to make it work and how they did it back then.... but i'm just plane fed up with messing with it and want to choose when to shift gears... not some stoopid liknage telling me when to shift hahahahahahaa
    We are all looking for some nice original chrome headers.. :D good luck..
  25. titus
    titus
    Real hot rods have sticks anyways right!
    You might be able to get away with just using the lasalle the way it is, if the trans mount is in the same close area it would be a heck of alot easier than changing the crossember etc etc.
    the trans you have has a fixed yoke on it so you have to have a slip yoke driveshaft wich it pretty easy since alot of trucks had that stuff.
    im also kinda wondering if you can just find a yoke that fits the trans and use it as a slip yoke, i thinke only major difference is that the output shaft is a tad longer.
    I also have about 10 lasalles, i believe the insides are all the same so maybe you should hang onto your side shift trans for parts for your topshift.
    but if you need any parts let me know, i got a couple from Johny long ago that were taken apart so i alot of extra parts.
    JEFF
  26. Lucky Burton
    Lucky Burton
    I'm ready P.. Let's do this *****!!!
  27. 53chevy
    53chevy
    This hot rod build is sounding more like "Theater of Pain" than "Live Wire", Hahahaha
    One last thing...make sure you tie your Dokken bandana to the shifter.
    Ken
  28. enloe
    enloe
    from east , tn.
  29. Evel
    Evel
    Yeah it think the mounts are pretty close.. We have some machine shops close to Luckys shop that do race car stuff so any thing can be made..
    Theres a few things i'm gonna need.. I'll call you when I figure it all out..
    Thanks for the advise I'm sure i'll have to pick your brain..
    Sold the side shift.
  30. Evel
    Evel
    Ha!!
    Soon it will be Dr. Feel good!.
