Projects Living the Dream - '30 Coupe
Discussion in 'Traditional Hot Rods' started by Tumblin' Dice, Dec 4, 2023.
  1. Outback
    Outback
    from NE Vic, Oz
    Sub'd, a grouse coupe! Love the chop & direction you are headed
    Stogy and Tumblin' Dice like this.
  2. 282doorUK
    282doorUK
    I've always found that trusting to serendipity and happenstance to get things done often gets better results than franticly chasing around after something, what a great find, it looks just right!
    I'm on a similar journey with my '31, I just wish the last owner had pre-chop it for me though!
    Subscribed..
    throughbeingcool and Stogy like this.
  3. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    I totally agree. The car will become whatever it's supposed to become, I just need to not screw it up... having the pre-chop is very nice!
    One thing that will be a priority is getting some shocks set up. Low-speeds it's fine, but at 40mph+ the car does pogo a little when it hits road imperfections.
    There were no shocks on the car when I bought it. I looked at a lot of ways to mount tube shocks, the reversible kits that the parts houses sell, bending up an F100 shock mount for the front... A lot of ugly solutions and solutions I don't have the ability to do at the moment (no oxy-acetylene setup). I love the look of the Houdailles, but they are ungodly expensive for some reason, and I don't want Chinese stuff on this car, so...
    I played around in CAD and I think I can have my own friction shocks machined that will do the job better, and for about the same money as the Offenhauser ones that Speedway sells. The bushing material will be Delrin, and I'll use the shock ball ends to mount to the later Ford style dogbone shock links. Should work pretty well and look okay.
    In order to take up the offset between the frame and the dogbones I'll have to measure once I get the prototype in hand and either bend the arm out accordingly, or just add more Delrin discs to the ***embly if the distance isn't too great. Opinions welcome.
  4. Tim
    Tim
    from KCMO
    Love it, keep us posted
  5. swade41
    swade41
    from Buffalo,NY
    I like the changes, it kinda looked odd before with the heavy chop and tall stance, reminded me of a crop sprayer.
  6. 282doorUK
    282doorUK
    Shock drawings look good, but I'm not sure about the Delrin, it's very slippery and I often use it for making bearings for one off jobs, like a thrust bearing behind a chuck for tool post mounted cross drilling fixture on my lathe which has stood up to a lot of pressure and high revs very well.
    Leather was often used back in the day and might be a better choice.
  7. CSPIDY
    CSPIDY
    My Tudor has friction shocks
    I found that the rubber tends to stick and bond to the friction plates
    this causes the shock to rip apart, welded back up
    and
    I have added a film of grease on the rubber and this has prevented sticking
    car rides very smooth and doesn’t bounce
    You will need a spring plate so you can adjust the friction
    Stogy likes this.
  8. Outback
    Outback
    from NE Vic, Oz
    We use a type of plastic in the friction shock's at work. They work well.
    Originally they had timber disc's - (English/Euro)
    Stogy likes this.
  9. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    All four wheels are in the same ZIP code now. Time to blast them and give them a new coat of paint and then we can finally put the new rubber on.
    Dannerr, catdad49, Jeff34 and 11 others like this.
  10. AHotRod
    AHotRod
  11. Really nice car!!!! Looks great!
    Stogy likes this.
  12. CSPIDY
    CSPIDY
    Are they Ford or KH wheels?
    I’m running two sets of 35 Ford wheels with no tubes, and no leaks
    precision manufacturing
    Dannerr, throughbeingcool and Stogy like this.
  13. woodz
    woodz
    Just saw this thread. What a great Coupe. Congratulations. Love where you are going with it.
    Subscribed.
    Stogy likes this.
  14. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    Not much going on lately other than driving, I ordered a set of tubes with the wrong valve stems, so I'm just waiting to receive those before I can go ahead and mount the tires. I can probably get away with tubeless as most people seem to do, but... we'll see.
    I did want to add some more volume, though, so today I installed a Cherry Bomb "Old Skool" Hot Rod Muffler in place of the OEM style. I made the mistake of firing her up with no mufflers before installing the new one, and the sound of a straight-piped banger is one of the best on Earth, so consequently the Cherry Bomb sounded a little underwhelming (but is still definitely an improvement).
    There's very little real-world information about this muffler out there, but at $30 I think it is a great alternative to a Porter or something similar, if you are "budget-minded" like myself. Unfortunately, it is made in Mexico... can't have it all.
    I installed it with the openings of the louvers facing into the flow of the exhaust, but Cherry Bomb claims this muffler is "reversible." A little quieter than I'd prefer at idle, but is definitely opens up when you hit the throttle. Tone seems a little raspier than the open header. I'll post a video of the sound at some point for the next guy researching this muffler. For $30, I don't think anyone could really complain.
    You'll notice this job is basically half-***ed... I'll be needing to re-do the exhaust entirely this summer and will whole-*** it then, but that's for another update in the near future...
  15. The37Kid
    The37Kid
    Nice car! Next time you have a tape measure could you tell us how tall the window gl*** is? Bob
  16. -Brent-
    -Brent-
    I love watching this coupe evolve.
  17. Jacksmith
    Jacksmith
    from Aridzona
    Those wheels & tires are going to give a whole new at***ude! Can't wait to see 'em installed...
  18. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    Thank you! The side windows are just about 9" on the dot. If you want any more measurements let me know.
    Dannerr likes this.
  19. The37Kid
    The37Kid
    Thanks! I've cut my Steelback doors for 10 inch, seeing your Coupe gives me an idea how things will look. I'm happy.:)
    Dannerr, Tumblin' Dice and Outback like this.
  20. Jacksmith
    Jacksmith
    from Aridzona
    The 16s are gonna make a huge difference. So... what sizes are those tires ? They look spot on to me!
  21. ironandsteele
    ironandsteele
    This car is tough as nails. I love it.
    ironandsteele.com​
  22. I really dig this car and I'm enjoying its evolution. Subbed.
    Tumblin' Dice likes this.
  23. Outback
    Outback
    from NE Vic, Oz
    @metalhead140 has a coupe that has a similar chop & is a banger, check out his thread! Another very cool jigger!
  24. SS327
    SS327
    Please keep the A radiator grille. Everybody goes to the 32 B style and I’m just tired of seeing belly ****ons. The A style is much prettier.
  25. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    Oh yeah, that's a great looking car. Almost makes me want to keep the bigger A wheels on mine and do a little rubber rake on those. Maybe one day....
    Don't worry, to me all of the Ford grilles are iconic in their own way, and I think that A coupes usually look better to me with A grille shells. I like the character of the car with this and it's going to stay that way.
    And, I agree with you about belly ****on hot rods. I am trying to strike a balance between making this a hopped-up, banger-powered hot rod I can take long road trips with, using as many old parts and build techniques as reasonably possible while not losing the forest for the trees, and also not making it another copy-paste car. To that end, hopefully I'll have another update this week...
  26. I like it with the stock wheels. I would like a Model A (or other brand) sedan with a heavy chop and skinny wheels.
    Dannerr and Tumblin' Dice like this.
  27. Model A Gomez
    Model A Gomez
    My avatar had a flatheadV8 and kept the stock tank, my 30 Pickup had a B motor with a Winfield head, Ansen manifold with a Holley 94 and header and stock tank. There's no problem with the stock tank but always turn the gas off when you park it. Starting on a 29 roadster pickup with a warmed over banger, dropped axle and 16" wires.
  28. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    I love a good mail day, and today was definitely one of those.
    I scored this '28 Chevy head from a fellow HAMBer. It looks like it's in better shape than I was expecting, and I'm planning to get all my ducks in a row and "cutover" to this head sometime in the summer.
    Plan is to run the Jern adaptor plate (which I don't currently have at the moment), and it should be a piece of cake to CAD out a water pump adapter (thermosiphon head originally) and pushrod cover/exhaust plate, as well as a distributor adapter.
    Taking suggestions for carburetor setups as well now. I won an auction for a Reese Fish carb a while back, but the government of England said I couldn't have it, I guess, and they didn't let it leave the country. So, we're back to square one. Two sidedraft Fish carbs coming off thing would have been an awesome look, though, if not 100% era-correct...
  29. 34 5W Paul
    34 5W Paul
    from Fresno CA
    Not familiar with this setup, seems fascinating. A quick web search turned up an adaptor plate like the one below. So many questions. Seems like a m***ive combustion chamber, what kind of compression will you end up with?
    Dannerr and Algoma56 like this.
  30. Jeff34
    Jeff34
    Great car! Lovin' this thread!
