Lock washers on my flywheel bolts - yes or no?
Discussion in 'The Hokey Ass Message Board' started by ford 223 gurl, May 28, 2010.
  1. The reason I ask is because in my manual there are 3 exploded views. 2 do not show lock washers and 1 does. Also there is no mention of them in any of the text. :confused:
    Also should I torque the pressure plate? Also no mention of this in my manual.
    Thanks. ;)
  2. randydupree
    randydupree
    from archer fl
    no lock washers on flywheel bolts.
  3. need louvers ?
    need louvers ?
    ...and I would torque everything correctly! Oh, a little locktight would not be a bad idea on the flywheel bolts too.
  4. It says 75 - 85 lbs for the flywheel, but nothing for the pressure plate. I assume it needs it too.
    Any suggestions?
    And I had planned on Loc-tite for the bolts, thanks.
  5. dirt t
    dirt t
    1. HAMB Old Farts' Club
    Some do use star washers . Torquing a bolt never hurts. I have a a chart that lists bolt size and what it is torqued to. What motor is this?
  6. Nobodys Hero
    Nobodys Hero
    from New Jersey
    I would wire tie the bolts as well
  7. It's a Ford 223.
  8. RDR
    RDR
    torq them and locktite...
  9. I learned years ago that if you are unsure...tighten till it strips then back off half a turn.
    Seriously though, I use high temp permanent threadlocker and somewhere here on the net (as mentioned in an earlier answer) there should be a chart listing the torque specs for bolts based on their diameter...e.g 1/2" bolts gets ____, 3/8" bolts get ____...etc Good luck
  10. holeshot
    holeshot
    from Waxahachie
    GURL...the older flywheels use lock washers, but some new ones don't. yours probably doe's. and definately TORQUE flywheel and pressure plate bolts...POP.
  11. 61bone
    61bone
    If 3/8s uss -35 ft lbs If 3/8s sae- 39 ft lbs. blue locktite
  12. Fordguy321
    Fordguy321
    from Arizona
    just a few rat ta ta ta tats of a 3/8 impact wrench! LOL
  13. gnichols
    gnichols
    from Tampa, FL
    Won't the engine's direction of rotation keep them tight? Gary
  14. MR.BROWN
    MR.BROWN
    I just did a 351 Cleveland for a guy with no lock washers. I torqued them to spec. After he got exhaust on the car he came back down to my shop for a once over everything. Guess what, it had a strange knock that got worse the slower the engine ran. Hmmm?
    I pulled the bastard out! All but one of the Flywheel bolts had come loose. The little star washers are VERY important! Most times there is not enough clearance for a regular lock washer, but I would strongly recommend the little star washers in every application. By the way the car is a 70 mustang with big tube race headers, an 8 quart oil pan, and is a complete nightmare to work on.
  15. Star washers and a dab of lock tite.
