lock washers
Discussion in 'The Hokey Ass Message Board' started by Twobit, Apr 16, 2013.
  1. Twobit
    Twobit
    Something I have wondered about for some time.
    If you put a flat washer under the lock washer and nut does the lock washer work like it is designed to?? The flat washer is free to turn; not locked.
    Regards, Twobit
  2. belair
    belair
    and if a tree falls in the forest...
    I would say yes, it still works-the lock washer is still putting tension on the nut, and it is very doubtful the flat washer will be free to turn.
  3. It does not matter!
  4. Still works fine.
  5. indyjps
    indyjps
    Loctite is about 10 times more effective, just a drop of blue
  6. Cerberus
    Cerberus
    You got me wondering. Split lock washers turn smoothly when you tighten them. But they are designed to dig in when they are backed off. So when backing them off does it cause wear and you shouldn't re-use the lock washer?
  7. tikiwagon13
    tikiwagon13
    Using a flat washer between the lock washer and the surface of the clamped part will work, in fact it is recommended as the flat washer will disperse the load and prevent the surafce from being marred by the lock washer and possibly creating a stress fracture, dedpending on the material. If the componants are critical try not to reuse the hardware as the mechanical locking forces are reduced. Although not period correct the nylock nuts are preferable. The rule of thumb is mechanical locking on a nut and bolt, safety wire on a blind fastener and chmical as a last resort (loctite)
  8. merking56
    merking56
    from NJ
    Well put!
  9. the spring tension of the lockwasher is what keeps the nut from backing off, in my trade we use conical spring washers for transformer and power distribution terminations. This looks like a flat washer that is "cupped", this applies the necessary force if not over torqued.
    And Coastfab.com
    Have a lot of info too
  11. TagMan
    TagMan
    I never reuse a lock washer and I only buy & use grade 8 lockwashers, regardless of the application. I've found the grade 8 lock washers hold their shape or "springiness" better.
  12. Mike VV
    Mike VV
    from SoCal
    Just do a Google search. The standard, one surface "lock washer" isn't very effective at locking fasteners from vibration induced loosening.
    Star washers are good, Loctite, safety wire are about as good as you can get.
    I try to stay away from the "one surface" type lock washers. My cars, I use star lock washers, Loctite and safety wire. My motorcycles, I use...the same.
    Mike
  13. tikiwagon13
    tikiwagon13
    The bible, written by a god
  14. Blue One
    Blue One
    from Alberta
    I will never use the standard split spring type lock washers on anything. Period.
    I'll use locking nuts, nylock or otherwise, or loctite.
    I have seen far too many of the split spring lock washers that break and then the pieces fall out leaving the fastener loose and on it's own.
    For the most part that style of lockwasher is junk.
  15. noboD
    noboD
    And don't forget to use left handed lock washers for left handed threads. They can be bought!
  16. derbydad276
    derbydad276
    the SAE did a study a few years back and found that lock washers are not worth the time
    nylock nuts or stover nuts or locktite are the way to go
  17. Partsman2012
    Partsman2012
    If you have a real problem fastener, you might try Nord Lock washers from McMaster Carr.
  18. If it's tight that flat washer is not going to move. HRP
  19. I work as a millwright for US steel, they will not let us use split lock washers. They say that they break and fall out, leaving the bolt loose. I've seen it many times.
  20. tfeverfred
    tfeverfred
    I have NEVER seen or even heard of a lock washer backing off. In fact, I have them on my pitman arm and steering arm and other parts of my car. They haven't even changed position in the last 4 years. Use them in combination with a flat washer and forget about them.
    Not using them is as crazy as using grade 8 fastners in EVERY application. Over kill at it's finest.
    I know the HAMB is slow during working hours, but really. Lock washers?
  21. Blue One
    Blue One
    from Alberta
  22. tfeverfred
    tfeverfred
