Technical Lockar shifter, altering it's length ?
Discussion in 'The Hokey Ass Message Board' started by BigO, Jun 2, 2018.
  1. BigO
    BigO
    Hey guys and dolls, I just bought a '47 Ford with a very tall Lokar shifter, I've never had one and don't know how it's put together so I'd rather ask fist and not get myself into trouble. So, here's what i'm asking, has anyone shortened one before or is it not a good idea, they are too expensive to just replace. Thanks for the help. BigO (Michael)
  2. 2935ford
    2935ford
    Inside the lever is a cable. Not sure how you shorten it?
  3. greybeard360
    greybeard360
    Be hard to do. You may be able to buy just the stick thru them.
    BigO likes this.
  4. 4wd1936
    4wd1936
    from NY
    As I recall the cable is actually the wound outer cable used for all kinds of applications. All it does is push on the locking mechanism. I don't see why you couldn't cut both it and the shifter the same amount and rethread the tube for your knob.
    BigO likes this.
  5. Call lokar,
    They will sell a shorter stick or any other part of the shifter ***embly you need.
    Where's that little bracket, for the shifter?
    I don't know you had it.
    Doesn't matter, I need the damn bracket - look for it.
    I've bee looking for an hour and it ain't anyplace I've looked and it damn sure ain't where it's supposed to be.
    Awe ****- call lokar and order it up.
    2 days it shows up on the brown truck.
    A week goes by and then his old lady found it in the dryer.
    BigO and Budget36 like this.
  6. Budget36
    Budget36
    My life it seems, I'll spend 4 days looking for something, know in I have 3 of them instead of going to town and spending 4 dollars.
    Of course I come across them about an hour after buying one.
    reagen and BigO like this.
  7. 26 T Ford RPU
    26 T Ford RPU
    I have an American Shifter which is a cheap copy of a Lokar and I shortened mine by 5 3/4''. I removed some from both ends and as for the cable just trim it to suit. Weld it up with a TIG. JW
    BigO likes this.
  8. BigO
    BigO
    That's a good thought, thanks.
  9. BigO
    BigO
    Ok, that's reasonable, thanks.
  10. BigO
    BigO
    Haha, that sounds like me , that's Hot Roddin, thanks I'll contact them and go from there.
  11. BigO
    BigO
    Hahaha, gotta love it.
  12. BigO
    BigO
    Thanks, I just didn't want something that should be simple to turn into... well you know.
  13. BigO
    BigO
    Thanks guys for all the help so quick, I love the HAMB.
    26 T Ford RPU likes this.
  14. 26 T Ford RPU
    26 T Ford RPU
  15. The Lokar "stick" is pretty basic. It's a hollow tube with the cable/stem running up through the inside. The problem is the tube is tapered, 3/8" threaded at the top and 5/8" or 3/4" (I forget the size) at the bottom. This probably means you won't be able to shorten it by half and cut new 3/8" threads at the top with a die because it will be a 1/2" +/- in girth. You might get away with shortening it an inch to inch and a half but no more. (If you're pretty handy and have a well-equipped shop, you maybe could fabricate a male/female adapter to transition back to the 3/8" thread at the top.)
    Some other good options are to trade the long one you have for a shorter one someone else has. The other guy is going to want to also trade your cable for the reverse/park interlock too. Another option is to get rid of the Lokar shift knob and replace it with something radical and funky that you want sitting up high and proud. Lokar has adapter kits for aftermarket knob installs.
    *****I just happen to be one of those guys with a short Lokar shift lever who is looking for a longer one. I haven't done my install yet so I already have a new, long, uncut cable. All I want is the outer lever. I'm your best answer. :cool: Send me a private message and we'll talk.
    roundvalley and BigO like this.
  16. 26 T Ford RPU
    26 T Ford RPU
    And after. I retained the thread for the Knob by removing some from below it and welding it back on. It very easy to do. JW
  17. 1956 F100
    1956 F100
    from Louisiana
    I cut mine and rewelded it so the splice was inside the leather boot. Just be sure not to have the weld penetrate through the tube as to prevent the cable from freely sliding.I then cut the cable back so it worked. Was actually pretty easy.
    BigO and The Shift Wizard like this.
  18. 26 T Ford RPU
    26 T Ford RPU
    Good point about the weld/cable interference as I had that issue and the weld was so hard I couldn't drill it, cut the weld out and did it again but better. JW
    BigO likes this.
  19. jkski
    jkski
    wound copper wire around a tube the size of the channel,inserted it in the tube with single strand of it sticking out the bottom.Did the weld at the cut pulled on the strand till it all came out.
  20. David Gersic
    David Gersic
    from DeKalb, IL
    Just buy the shorter stick. It comes with the cable. Swap it out, sell the long stick to recoup most of the cost, and done.
    robracer1 and roundvalley like this.
  21. 26 T Ford RPU
    26 T Ford RPU
    When I had to cut mine it was already the shortest swan neck one. That was what I wanted
    so I had to cut it, was trying for an early Ford look..well kind of. JW
    BigO likes this.
  22. BigO
    BigO
    Thanks , that's what I was afraid of. Great info for me and others.
  23. BigO
    BigO
    Thanks, that can work.
  24. BigO
    BigO
    Thanks for that good point about the weld penetration.
  25. Joe H
    Joe H
    I bought a shorter stick for mine off e-bay for a decent price, cheaper then from Lokar. I still have the long lever if you mess yours up and need one. Both ends are threaded and the cable could be cut easy enough.
    Joe
    BigO likes this.
  26. BigO
    BigO
    Thanks, thats good to know. Appreciate the offer.
