1952-59 Ford locked up brakes
Discussion in 'Off Topic Hot Rods & Customs' started by lanny haas, Mar 28, 2010.
  1. lanny haas
    lanny haas
    from Phoenix AZ
    Took the little Ford out for a drive saturday stopped at ACE to buy some hardware, got back in the car to pull out of the parking space, and the left front was locked up, and the brake pedal hard. I lossened the brake line to the left front, and she rolled again, but I could feel it stiffing up on the way home. Thinking master cylinder, or a wheel cylinder. I have the parts to rebuid both. Next weekend project. Ill let you know what I find.....
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    I had the same problem in a '53 I once had,it was the brake hose causing the problem, internal swelling was causing the fluid to not return after releasing the pedal.Not uncommon for rubber to go south in AZ!
  3. lanny haas
    lanny haas
    from Phoenix AZ
    never thought of that!!! Im sure they have been on ther since 53, thanks for the tip. Ill look for new ones just in case.
  4. missysdad1
    missysdad1
    I had this problem with the rear brakes in my daily driver '64 El Camino. Turned out to be same as Jeff, internal swelling in the rubber brake line. Changed the line, problem gone. Good luck!
  5. JeffB2
    JeffB2
    from Phoenix,AZ
    Lanny,put this number in ebay search 170452855500 I got mine from them and the quality and fit was A+ perfect this price is for all 3 hoses which is about the price of one locally,word of caution when you replace the rear hose clean the road grime from around the tee fitting and give the threads a good soak of PB Blaster the br*** tee is easily stripped.Also be sure you use a flare nut wrench on those fittings.
  6. Chalupa55
    Chalupa55
    from So-Cal
    JeffB2 I was looking at those brake hoses for my Ranchero from them. I was reading that there may be other costs to get them here from Argentina. Did you have any other costs to get them here? Thanks.
  7. JeffB2
    JeffB2
    from Phoenix,AZ
    No,just the shipping as posted on ebay.
  8. lanny haas
    lanny haas
    from Phoenix AZ
    I see he starts at 1954 up on the brake lines. is a 53 the same animal?
  9. JeffB2
    JeffB2
    from Phoenix,AZ
    OOPS! Click on this ebay # 360248194789 this is correct for 52-53 Mainline and Customline,I checked my parts manual 54-56 use the same hoses and 52-53 hoses are the same in the rear but 52-53 fronts are 13" and 54-56 are 14 3/4" long.
  10. lanny haas
    lanny haas
    from Phoenix AZ
    I emailed the guy and told him I wanted the 53 mainline. So I guess im geting he right one, if not I'll be selling them on the bay myself. but even so there only 1 3/4 inch longer????
  11. JeffB2
    JeffB2
    from Phoenix,AZ
    An 1 3/4" longer probably would work any way, the fittings are probably the same the extra length was due to the new ball joint suspension in '54.
