Technical Lockheed vs Bendix
Discussion in 'The Hokey Ass Message Board' started by seb fontana, Jan 21, 2026.
  1. seb fontana
    seb fontana
    from ct
    Has anyone or is there a kit to convert Lockhead [42-48 Ford] style brakes to Bendix [41-48 Lincoln] style? Can't just swap to Lincoln as the Lockheed brakes are 9" diameter.
  2. Mr48chev
    You will have to change backing plates to put Bendix brakes on them. You can't just change hardware on the backing plates.
  3. 1946caddy
    1946caddy
    from washington
  4. 31Apickup
    31Apickup
    39-48 Ford Lockheed brakes use 12” drums as do the Lincoln Bendix brakes.
  5. seb fontana
    seb fontana
    from ct
    The Lockheed brakes I have are 9" diameter. Can't just swap to Lincoln as the Lockheed brakes are 9" diameter.
  6. alchemy
    alchemy
    Why not find a Lincoln that was in the dryer too long?
  7. International Scouts from 1961-62 used 9" Bendix brakes however they look and operate very similar to the Ford Lockheed brakes. So you're either going to have to go to bigger diameter brakes to get the self energising style or work with what you have.
  8. 31Apickup
    31Apickup
    What exactly are you working on?
  9. seb fontana
    seb fontana
    from ct
    rims are 12", slight miss match
    early jeeps, nash, too.
    Yeah beam me up Scotty!
  10. 31Apickup
    31Apickup
    Jeeps used primarily Dana axles you could look for interchanges from other Dana axle equipped vehicles. Nash used some Dana but also ****er.
    seb fontana likes this.
  11. seb fontana
    seb fontana
    from ct
    Crosley. I have been trying to find 9" brakes from a early falcon/comet from early 60's up, can't find a whole set before they are thrown out when the cars are hot rod'ed. Yes I see bits and pieces on ebay but I would like a matching "set". I do have a set of Lockheed but would like the one better performance of bendix as I don't think the dual bore wheel cylinders are available for the 9" Lockheeds unless the 12" Fords would fit, with out the dual bore I think performance would be hindered.
