Technical Locking a banjo rear
Discussion in 'Traditional Hot Rods' started by panheadguy, Oct 19, 2024.
  1. panheadguy
    panheadguy
    from S.E. WI
    I'm wanting to lock up a banjo rear end....but in a way that could be reversed later. In other words without welding the hell out of the internals. Back in the day you could buy two tooth spider gears but I have not seen these for years. Anyone know if someone still makes them or of an alternate idea?
  2. Happydaze
    Happydaze
    Im no expert but for something to be reversible I think you'll be looking for a spool.
    Chris
  3. dwollam
    dwollam
    I welded between the teeth of some spider gears to lock up a rear end for circle track racing. I left the spiders removable, not welded together. Worked fine and worst that could happen would of been to wear the weld away and become open diff again but that never happened.
    Dave
    Unkl Ian likes this.
  4. panheadguy
    panheadguy
    from S.E. WI
    Exactly what I will do if I can't find some two tooth spiders
  5. '29 Gizmo
    '29 Gizmo
    from UK
    Pin the spider gears to the shaft so they can't rotate.
  6. Speedster
    Speedster
    from Tacoma, WA
    I just tore down my Cyclone quick change and the spiders were also welded up as you described.
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I have to ask. “Two tooth spider” gears?
    ClayMart likes this.
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ClayMart, Okie Pete and rusty valley like this.
  9. Enbloc
    Enbloc
    from London, UK
    How I did mine using worn out spider gears.
    Fully reversible which I was totally glad of as 500 miles in the novelty had fully worn off.
    Okie Pete and Koz like this.
  10. panheadguy
    panheadguy
    from S.E. WI
  11. panheadguy
    panheadguy
    from S.E. WI
    As was mentioned earlier....today you look for a spool which as far as I know doesn't exist for a banjo
  12. panheadguy
    panheadguy
    from S.E. WI
    Right!
  13. 38Chevy454
    38Chevy454
    Could you remove the spider gears and on bench just weld fill in a couple teeth to effectively make similar to the 2 tooth gears? No need to fill all the teeth, just the ones next to the axle gears to prevent them from turning. Still be reversible as long as you have an extra set of spider gears.
  14. alchemy
    alchemy
    Would using the less-tooth gear kinda mush the axle gear as it tries to turn into those shallow or non-existent teeth? Then the axle is no good if you wanted to convert back?
  15. JamieUC
    JamieUC
    from Swansea UK
    Those two tooth spiders look good, I've been trying to think of a way of locking the banjo on the belly tank, with it being rigid rear axle I get quite a bit of rear end hop under heavy acceleration and am thinking a locked rear diff would help. could just weld it up but not very reversable.
  16. dwollam
    dwollam
    That is what I was trying to describe that we did. Worked fine.
    Dave
  17. Harv
    Harv
    from Sydney
    I understand how spring wind-up can cause axle hop (tramp) under acceleration, and how Caltracs, ******* bars and traction bars prevent it. Not sure how a locked diff prevents axle hop though?
    Cheers,
    Harv
  18. Unkl Ian
    Unkl Ian
    What surface are you running on ? And how much power ?
    When you say "rigid rear axle", do you mean no suspension ?
