Hot Rods Locking Rear End for Model A
Discussion in 'The Hokey Ass Message Board' started by 52Truckin, Jun 25, 2025.
  1. 52Truckin
    52Truckin
    Did they make a locker, limited slip or other deferential for a model A? I plan on putting a Halibrand 101 quick change in my car but would like to make pull on both wheels without welding the spider gears.
    51 mercules likes this.
  2. xix32
    xix32
    My dad told me, what they did in the forties was: they took out the spider gears and ran a large thick wall tube through from one hub to the other. Then bored open the hubs for that large tube to p*** through. Cross drilled the hubs for bolts to connect the hubs to the new made axles. That was the end of broken axles. He raced at Andy Grantelli's hurricane ***cociation races at soldiers field Chicago after WW2. He once told me the ring and pinion were plenty strong enough, it was the axles that would break.
  3. Kevin Pharis
    Kevin Pharis
    from Califunny
    There were lockers for T’s, so have to ***ume also for A’s. There used to be a Suzuki Samurai clicker type locker that was easily modified to fit in a banjo rear… not sure about the details tho
