Loctite Red. Remove
Discussion in 'The Hokey Ass Message Board' started by strombergs97, Apr 9, 2008.
  1. strombergs97
    strombergs97
    Help, what is the best way to free an bolt that is already installed in my engine that was put in with loc***e red..Trying to remove oil pump adaptor, 340 Mopar pump in a 241 Red Ram..The engine had been rebuilt and only 200 miles on it..The oil pump shaft fractured and I want to install the new one that also comes with the adaptor..
    HELP..
    Duane.:confused:
  2. Bort62
    Bort62
    I've heard heat. I've never delt with it before.
  3. Zombie Hot Rod
    Zombie Hot Rod
    from New York
    Heat wrench...
    Put some heat on it first, then give it a couple of taps with a hammer and it should come right out... Notice the word "Should"...
  4. 55 dude
    55 dude
    heat it up and you should hear a "pop" when it comes loose, then loosen bolt
  5. HHRdave
    HHRdave
    from So Cal
    As mentioned before..... heat
  6. Jmountainjr
    Jmountainjr
    If it's in a place that you do not want to use an open flame, I've heated a piece of 3/8" or 1/2" steel rod cherry red and then held the rod against the bolt head to transfer engouh heat to loosen things up.
  7. Homemade44
    Homemade44
    As said in other posts, heating the bolt to about 350 degrees F will soften the lock***e and you can remove the bolt. If you get the bolt above that temperature it would be a good idea to use a new bolt when you install the new oil pump.
  8. nater
    nater
    Incase the other replies were not enough... Heat the thing up with a torch, and you will be good to go... most likely...
  9. 392_hemi
    392_hemi
    Hair dryer in close proximity for few minutes s/b enough to do it, or a soldering iron on the head of the bolt. Doesn't take too much to soften it up.
  10. belair
    belair
    good tips, 392
  11. sawbuck
    sawbuck
    from 06492 ct
    plumbers propane torch is all you need
  12. strombergs97
    strombergs97
    Thanks for all the tips, I like the soldering iron idea.."Excellent"...The HAMB rules..
    Duane..
  13. tigmusky
    tigmusky
    I'm with you . "Should"
    that "should work
    daye
  14. RilleCustoms
    RilleCustoms
    Yup ...little bit of heat ... heat gun , if that doesnt work heat up just the bolt with a small torch ....
  15. 325w
    325w
    Loc***e instructions say a little will do the trick.
  16. Al Napier
    Al Napier
    from Central CT
    I'll pile on the heat bandwagon. I've used heat on the fastener itself (don't get crazy but get it good 'n warm) with good results.
    Al in CT
