Lokar floor shifter for 700R4
Discussion in 'Off Topic Hot Rods & Customs' started by Tom Tidwell, Jun 9, 2024.
  1. Tom Tidwell
    Tom Tidwell
    Got a Lokar FM700DM shifter last week and bench tested the throw for clearance at seat. For some reason it only gives me 5 detent positions. Called Lokar and was basically told I was wrong. I got P,R,N,OD and D should reach 2 and 1 but it dead stops after D position. Like it is for a power glide. Installed according to directions and checked, rechecked and rechecked my recheck and it just doesn't have enough travel to grab 1st and 2nd. Dropped it in D, as far as it would travel and removed transmission end of linkage and manually went all the way t low gear and adjusted the rod to fit but when I try to go back to park the shifter stops at neutral. Calling Lokar again in the morning. It has to have the wrong detent setup in it or the whole shifter was packaged wrong. What say ye??
    chevy57dude likes this.
  2. Grumpy ole A
    Grumpy ole A
    Sounds like their QC messed up but it happens
  3. chevy57dude
    chevy57dude
    Here's a couple of pictures of the Lokar shifter I picked up at a swap meet. Detent plate shown, it has the number 700 on it. I checked it for operation, clicks in all the right places for a 3 speed w/OD. Then I noticed the knob jives with that, too. H 20240610_053503.jpg ope this helps.
    lothiandon1940 likes this.
  4. Sandcrab
    Sandcrab
    I have the Lokar on a 700R4 in the Austin and a 4L65E in a CJ 5 jeep. They both have the same ****on in the knob. When the setup is correct, there is a lockout in park and neutral so the engine can only be started in those positions. A ****on push is required to shift from either position. Then additional ****on presses and releases are required to move to the lower gears, but they are not necessary going from 1st to OD. It takes a little to get used to but eliminates inadvertent downshifting.
    Just a note mine are both case mount shifters.
    jazz1 likes this.
  5. Happydaze
    Happydaze
    I was gonna say that I thought there was a number stamped on the detent but wasn't too sure, but pics provided above seem to confirm this.
    Chris
  6. pprather
    pprather
    Well, OP has not been back since starting this thread.
    Thanks to those who tried to help.
    05snopro440 likes this.
  7. ekimneirbo
    ekimneirbo
    from Brooks Ky
    How many positions can you select without the rod hooked up? Did you push the ****on?
    19Eddy30 likes this.
