Lokar shifter knob adaptor owners step inside...
Discussion in 'The Hokey Ass Message Board' started by 409deuce, Dec 28, 2010.
  1. 409deuce
    409deuce
    Thanks guy's,
    In what manner does this adaptor kit work? Does that octagon shaped extension move up and down for the lock-out? Or is there another piece above it that holds the "non Lokar" knob and triggers the lock-out? Just trying to figure out how/if I can fab on a WWII chunk for a knob. Thanks again!
  2. Berky
    Berky
    You can use any shift knob that you want with the adaptor. The chrome part that you see actually slides up and down on an inner shaft. There is a threaded piece that the knob goes on and you adjust that to push down on the lock out. I just took one off an hour ago because it was sticking and wouldn't pop back up.
  3. themoose
    themoose
    As Rusty Rod said you can use any knob and to tell the truth I think the adapter works better that the stock knob with the center insert. Much easier to push down on the whole knob to release the lock out than it is to use your thumb on the center of the stock knob.
  4. 36fred
    36fred
    Ya bought one when they first came out, they dont work for beans. took it off almost as fast as it went on.
  5. 409deuce
    409deuce
    Awesome Rusty! Just the info I was after. I wonder how much weight that set up will take? I guess I'll find out.
  6. 409deuce
    409deuce
    Wanted to thank you guys for your info. Thought I'de show the finished results of my ww2 p-40 trigger control....
    Aussiepete. likes this.
