Technical Long Tie Rod Ends for Wishbones
Discussion in 'The Hokey Ass Message Board' started by Richard Reed, Jul 31, 2018.
  1. Richard Reed
    Richard Reed
    from Maine
    I`am looking for 11/16th, 7 degree taper tie rod ends with an overall length of 6". The ones I got from Speedway are too short. My problem is the running board bracket was in the way and had to move the split wishbone bracket further back. I thought about welding a piece of 11/16th threaded rod to make it longer but that wouldn`t be safe. Any other ideas would be greatly appreciated. Thank you.
  2. 41rodderz
    41rodderz
    from Oregon
    Good call on not welding extra on rod ends. Could shift liability on to you. I would see if you can modify or move running board bracket or change to hair pin. Pic would really help.
  3. Richard Reed
    Richard Reed
    from Maine
    The photo shows the tie rod lined up but with only two threads holding it. If I moved the plate forward then the bung wouldn`t be correct in the radius rod.
  4. Fordors
    Fordors
    For starters I don’t like the idea of a bolted on radius rod mount. Remove what you have and cut and modify it so it can be welded to the frame below the running board bracket.
    That will put the mount in the correct position. What are the plans for this car? Is the frame boxed?
  5. Hollywood-East
    Hollywood-East
    Thought the exact same thing...
    gimpyshotrods likes this.
  6. alchemy
    alchemy
    How about you remove the rivets from the body mount, sandwich the wishbone bracket underneath it (I think the body mount holes are slotted a bit so it shouldn't matter if they are moved 3/8" out), and then you might need to shorten the wishbone a skoosh before welding in the bung.
    seb fontana and upspirate like this.
  7. treb11
    treb11
    Pewsplace and alanp561 like this.
  8. Pewsplace
    Pewsplace
    ^^^^^^ What he said. Various lengths of bungs are available.
  9. 40ragtopdown
    40ragtopdown
    This might work to. wishbone.jpg 3/8 angle iron 7 degree bung on inside .
    Fordors likes this.
  10. Automotive Stud
    Automotive Stud
    I ***ume those are split model A wishbones? Have you considered splitting a later wishbone that is longer and using that instead?
  11. woodsnwater
    woodsnwater
    from North Al.
    Wow, so many good solutions to the same problem. This place rocks!
  12. Buckster
    Buckster
    Why not move the bracket to the inside of the frame?
