Technical Longer clutch fork pivot ball stud
Discussion in 'The Hokey Ass Message Board' started by wdglide, Jan 24, 2021.
  1. wdglide
    wdglide
    Need some ***istance on my clutch setup. My fork has little room to travel back once it is touching the diaphram. When the fork is pushed back it barely moves the clutch diaphram. When the fork is centered in the window the throwout is a full inch away from the pressure plate.
    I am looking for a longer pivot ball stud. I know there are a number of lengths. But I cannot find a part number or an application. My local parts stores are no help. I've saw one adjustable one at Summit, but it appears to only be about 1/4" longer.
    Does anyone know of a part number or a source for the longer ones?
    392 Hemi
    Hot Heads chevy adapter.
    Hot Heads flywheel
    Ansen SBC Blowproof bell with a standard pivot ball (about 1.5")
    Hays clutch (10.5")
    Speedway fork (link)
  2. wdglide
    wdglide
    This is the fork position when touching the pressure plate.
  3. Budget36
    Budget36
    Could it be you need a different throw out bearing?
  4. wdglide
    wdglide
    Yes. That would work also. But I can only locate the standard size. I would need one an inch taller.
    Bear in mind my search skills are not the best.
  5. Budget36
    Budget36
    I recall there are 3 different lengths of Chevy TO bearings. Not sure of your TO being used, if you know then that may help in your search? Or maybe lead you in the right direction.
    jimmy six likes this.
  6. DDDenny
    Take OUR word for it, once you improve your internet search skills your hot rod knowledge base will increase exponentially.
    egads, Budget36 and wdglide like this.
  7. 2OLD2FAST
    2OLD2FAST
    from illinois
    Whatever search engine you're using , search " Chevy throwout bearing sizes/ lengths"....
    Then " Chevy clutch pivot ball options/ sizes"
    alanp561 likes this.
  8. 427 sleeper
    427 sleeper
    What style of pressure plate?
    3 finger Borg & Beck, 3 finger Long style (Ford), flat finger diaphram, or bent finger diaphram?
    That should narrow down the T/O bearing type, you can fine tune with the stud after that, if need be.
  9. Budget36
    Budget36
    One other option I would suggest, is contact those who you bought your parts from and explain your issue to them. Most likely they will be able to tell you the solution
  10. jimmy six
    jimmy six
    I’ve 4 different lengths of TO bearings in my stash. I also have 4-5 different forks. If you get a longer bearing you can add a lock washer under the pivot ball if it screws in from the inside. On one that screws in from the outside I’ve cut the ball off and actually drilled and threaded both ends for a shouldered stud. PITA but doable.
    alanp561 and Budget36 like this.
  11. brading
    brading
  12. no55mad
    no55mad
    Memory seems that Speedway sells an adjustable length pivot ball. Used one on a Nailhead application.
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
