Looking for 727 yoke????????
Discussion in 'The Hokey Ass Message Board' started by brawal128, Nov 19, 2010.
  1. brawal128
    brawal128
    If you guys know of someone that has a 727 yoke, I believe it should a 29 spline. I need to get my hands on one. Let me know..
    Thanks
    Brandon
  2. 73RR
    73RR
  3. el Scotto
    el Scotto
    from Tracy, CA
    Junkyards tend to have them attached to driveshafts in trucks usually, too...
  4. Every junkyard I've ever been in has them.
  5. brawal128
    brawal128
    What style of truck was the 727 most common in and what year?
  6. sunsetdart
    sunsetdart
    the input yoke for the 727 is also the same as the one for the 4 speed. now you have 2 places to find one.
  7. Balls Out Garage
    Balls Out Garage
    from Arkansas
    Is it a bolt-on or slip yoke?
    If bolt-on, you'll need to look primarily at 3/4 ton and up trucks and motorhome chassis.
  8. brawal128
    brawal128
    It is a slip yoke. I know they have them on ebay for around 80-120$. I just wanted to see if I could find one at the yard.
  9. mj40's
    mj40's
    Why not put a want ad in the H.A.M.B. Classified?
  10. brawal128
    brawal128
    Yeah I'm going to that. But, wanted to start here first and see if anyone had info about what make and model the 727 came in.
    B
  11. 73RR
    73RR
    The 904 was not used in trucks, for obvious reasons, so any truck, starting in 1964, with 2wd or (an older) 4wd with a divorced transfer case will have the 'normal' 727 and a slip yoke on the driveshaft.
    Every passenger car with a big block will have a 727; No 904's and no O/D units.
