Looking for a clutch fork
Discussion in 'The Antiquated' started by Van Andrew, Jan 19, 2026.
  1. Van Andrew
    Van Andrew
    I replaced the clutch in our 1959 Chevy Apache. It has an original 283 cu in. with 3 on the tree.
    I discovered the clutch fork is not the correct one. It is for a '60-'72. Its flat (no bend) and has two slots on the end. Its supposed to have a forward bend in it and a single hole on the end for a D shaped adjusting rod. I was able to order new linkages ( smooth pin and adjusting bolt) but not a correct fork.
    The problem is the linkages rub the crossmember and the adjusting rod is too short. I ordered one from a fella on EBAY, but its Y is bigger than my throw out bearing. Must have been for a 2 Ton?
    Anyway I was thinking that there are lots of folks who change over to an automatic and maybe I could reach out and find a correct fork sitting on someone's shelf they are willing to part with.
    Thanks for your time.
  2. jimmy six
    jimmy six
    BigRRR and Fordors like this.
