looking for a flange
Discussion in 'Off Topic Hot Rods & Customs' started by Don56, Mar 11, 2025.
  1. Don56
    Don56
    I have a 181 mercruiser from the early 70's that I'm putting into a trike. Does anyone know of a person or company that makes an intake/exhaust flange? All the machine shops around here say that it will take more time to create the program than it will to cut it out. I cut the stock manifold down but I need a flange to weld my headers to. Thanks.
    tractorguy and Just Gary like this.
  2. treb11
    treb11
    tractorguy likes this.
  3. Joe H
    Joe H
    I've made a number of flanges from flat stock using gaskets as patterns. Hole saws, files, rotory cutters, what ever it takes to round out the holes. Jigsaws also work. Torch or plasma cutter will do alright, they tend to harden the edge some, but once its cut away you are good to go. Water jet companies are around and cam cut any thickness you need off gasket patterns.
    The Chevy Pope and tractorguy like this.
  4. FrozenMerc
    FrozenMerc
    You can do it like Joe H, which most us have done it that way, or you can find a buddy with CAD who can draw it up for you. Should only take 10 mins, for a simple flange. Worst case, put your hand drawing and a $50 bill in an envelope and send it my way. I will send you back a flange, cut out of your choice of material within a couple of weeks.
  5. tubman
    tubman
    There is a company called "Send-Cut-Send" that does exactly this. I have a friend who uses them all of the time, and he has had some pieces made for me. One example was a couple of "Hurst style" motor mount adapters for an early hemi. I think they can work from full-size drawings or certain types of CAD files. Check them out. Hemi Mount 1.JPG Hemi Mount 2.JPG
  6. Just Gary
    Just Gary
    Headers by Ed made my Hemi header flanges. They're beautiful.
    http://www.headersbyed.com/
    Caution: he loves to talk on the phone.
  7. oldolds
    oldolds
    I will admit to knowing nothing about what I am going to say next.
    It would seem an easy thing to do these days.
    Couldn't a computer scan of the gasket be fed into a cutting machine?
    It should take less time to do it than for me to type this.
    Just Gary and The Chevy Pope like this.
  8. treb11
    treb11
    There is no "just have the computer...." a human has to touch the part, load the steel, clean and ship the part, etc.
    True, computers and lasers have made parts manufacturing easier and more accurate, but a human still has to work it at some point, especially for one-off parts as opposed to m*** production.
    That said, Hells Gate Hot Rods could probably fix you up:
    https://www.hellsgatehotrods.com/product-category/flanges/exhaust-header-flang
  9. Mike Lawless
    Mike Lawless
    20230718_154652.jpg I could make your flange....IF, I had a pattern to go off. I do all my stuff on old school manual machines.
    However, it might be better for you to seek out a local, or semi local outfit that can do CNC flame cutting or water jet. They would need a pattern too. Attached is a simple two bolt phenolic carb insulator I made. If it is a s imple as that, it's just a matter of distance between bolt centers and the main bore diameter
  10. pprather
    pprather
    @Don56 , are you returning here?
    I think we may have list him.
    If you return, are you able to post a photo of the exhaust flange gasket?
  11. e015475
    e015475
    from Phoenix
    If you live in a metropolitan area, I've had pretty good luck searching Facebook or Craigslist services for 'waterjet' or 'laser cutting'. The ones I used would make parts from a sketch or tracing. For an exhaust flange I'd think that'd be fine. For complex/precision parts I've used CAD services I've found on Facebook or Craigslist to generate a .dwg or .dxf file that I can take on a thumbdrive to a waterjet/laser facility. Etsy also has a bunch of freelancers that will make a CAD file from a drawing, but I've never used them.
    If you want to try your hand at it, you can download a free-ware program called 'Inkscape' and create a .pdf image of the part you need cut. I've made quite a few parts by taking a picture of the mating part, importing it into Inkscape, tracing the photograph then modifying/scaling the drawing to the dimensions I need. The laser cutting machines I'm familiar with will take a .pdf if it meets some specific requirements for line size and color.
    If you live somewhere remote, your best bet is probably SendCutSend. If you can make a sketch/tracing they also have a design service.
  12. Don56
    Don56
    Thanks everyone for the advise. I had talked to multiple machine shops in the area, they either don't do one off parts or they said it would take longer to program the machine than it would be to cut the part. That's why I thought maybe someone on here had done it before and maybe had the program on file.
  13. Be sure to post what you end up doing. My AVATAR has a 181 block with a temporary 153 head. You should add your general location and maybe someone will know a shop near you that would make one.
    Charlie Stephens
  14. Harv
    Harv
    from Sydney
  15. Don56
    Don56
    I found a local machine shop that will make my flange.
    One other question. I'm using a th350 transmission, the mount is at the rear, if I use a front cradle for my front motor mount, will that put the motor to transmission joint in an excessive bind?
  16. Please post their name if it comes out good.
    Charlie Stephens
  17. arse_sidewards
    arse_sidewards
    from Central MA
    Draw it in CAD or have a friend draw it in CAD and then use SendCutSend. Order minimum is like $30-40 though so have them draw some other stuff you want.
  18. Don56
    Don56
    The local guy I found wasn't going to do the job like I imagined he would, so I bought the adapter plate from Barr Marine. On one side the openings are normal, fit the head openings perfectly. On the newer head side the openings are quite a bit smaller. Will need to have a machine shop open them up to the proper size.
