looking for a good chrome shop
Discussion in 'The Hokey Ass Message Board' started by Kenn Evans II, Nov 22, 2011.
  1. Kenn Evans II
    Kenn Evans II
    I have a new project and I want to do a little unconventional chrome job and need a facility that can do minor metal tweeking and can chrome the body of my 1952 Kaiser Manhattan. I want to do the 4 doors, hood, trunk lid and cabin. Thanks for your suggestions.
  2. flamedabone
    flamedabone
    Check out Chromeplaterjosh here on the HAMB, he is the man.
    A whole car might be dicey, particularly if it needs any bodywork at all. You might be better off with one of the chrome spray on places. The process has been covered here if you hit the search ****on.
    Here is one example.
    http://www.jalopyjournal.com/forum/showthread.php?t=580579
    Good luck, -Abone.
  3. stude_trucks
    stude_trucks
    Chrome the whole car? Did you just win the Powerball or something?
  4. bulldogcustomchrome
    bulldogcustomchrome
    Your best chance of a chrome finish on an entire car is with a spray chrome. I do quite a bit of out of state work. Message me if I can help.
  5. nowaxn5
    nowaxn5
  6. Steeljeep
    Steeljeep
    from MI
  7. damagedduck
    damagedduck
    from Greeley Co
    ^^^^^^^X2:rolleyes:
  8. you might want to re think that. thiss truck made me put sun gl***es on to p*** him
  9. Yea, that would be subtle !
  10. maybe you should look at Chrome paint? I haven't heard much good thou.
  11. bulldogcustomchrome
    bulldogcustomchrome
    How often have you been behind an 18 wheeler with polished rear doors? They may be blinding but they look good.
    Sorry, wrong quote. I was responding to NoName.
  12. bulldogcustomchrome
    bulldogcustomchrome
    There is a lot of bad publicity out there about spray chrome. Not all chemical manufacturers put out quality products. It also takes time and practice for an applicator to hone his skills. The system really is pretty cool and has a lot of potential applications. As with anything, the process continues to evolve and improve.
  13. ChromePlaterJosh
    ChromePlaterJosh
    I know it can be done theoretically, but not by me.
    I'd be surprised if any shop was willing to plate all the parts, even with tanks large enough. There may be someone willing to do the doors, hood, and trunklid, but the cabin is a big stretch for real electroplating. It would be more realistic to have the exterior panels of the cabin custom formed from stainless, welded to the cabin, and polish the stainless. Or cut the cabin into sections, then bolt together after plating.
    Drainage is a huge issue, as body panels are constructed of multple layers of sheetmetal pressed together. Now consider that there are at least 4 different solutions each part must run through, plus rinses for all. They cannot soak long enough between solutions to flush out well enough without losing activation, so they have to be modified to drain really well and hope nothing is overlooked.
    Cross contamination of the solutions from one part (especially a big one) can literally stop plating operations for hours or even days until all is filtered and brought back to specs.
    Good luck. I like the ambition, and with enough funds available, this is something I would likely attempt myself, because I'm a little weird. Chroming a 32 roadster body would be a lot morr feasible.
  14. alchemy
    alchemy
    Now you're talking!
  15. rainhater1
    rainhater1
    from az
    check with ogden chrome in utah
