Technical Looking for a hilborn scroungers guide
Discussion in 'The Hokey Ass Message Board' started by SuperKONR, May 27, 2024.
  1. SuperKONR
    SuperKONR
    from Earth
    I've been half*** looking for a mechanical injection setup for a SBC for awhile. Is there a catalog I could download somewhere that has specs on the different part numbers for manifolds, pumps, nozzles etc? Been looking at Hilborn stuff as it seems like they are the easiest to find parts for. Would like to be able to figure out what part numbers match up for my application so that when I'm at swap meets or on ebay I can start picking stuff up.
    Thanks
  2. milwscruffy
    milwscruffy
    Be aware that Holley bought Hilborn and Hilborn is pretty much no more. So if you need parts, the search may take quite a while.
    SuperKONR likes this.
  3. SuperKONR
    SuperKONR
    from Earth
    Yes I was going to call them for info but Holley shut down the brand not too long ago. I see parts come up for sale but need to know how to ID what I'm looking for.
  4. RodStRace
    RodStRace
    While vintage catalogs will be your best source for matching up systems and parts, this may help you see what's available today.
    https://kinsler.com/Shop/constant-flow-mechanical/
    There have been threads here on Hilborn stuff and many searches lead back here. Keep trying different topics to look for old posts.
    EDIT: AND THIS GUY!!! next post.
  5. 402BOSSMAN
    402BOSSMAN
    I've got a few SBC Hilborn Injectors I just finished restoring. I'm the sole guy restoring and making parts for Hilborn Injectors. Happy to help any way you need.
  6. 1biggun
    1biggun
    My advice buy a complete set up and be sure it's set up the type of fuel you want to run .
    Lots of alcohol sprint car set ups for sale in the $1000 or so range .
    Not a lot of gasoline set ups for sale.
    The older 2 1/16" Hilborn set ups that take stacks held on with two screws like in my avatar are about impossible to find original stacks for. If you do there expensive.
    I have been looking .
    They often have a barrel valve with only one line in and no byp*** port.
    So there set up options are limited.
    Old Hilborn pumps are a **** shoot. No easy way to know if there good or not with out trying or having one flowed And there not made any more so new non hiborn ones might be needed
    Would be great if you can buy one off a running engine .
    I got a hodge podge of stuff and I suspect half I bought won't work for what I need.
    RodStRace likes this.
  7. Kevin Ardinger
    Kevin Ardinger
    I’ve been looking myself. I just keep talking myself out of it because of drivability on the street. I’m afraid it will be a constant struggle.
    Looks like 402BOSSMAN may be the connection. At one time A60sracer had several for sale.
  8. catdad49
    catdad49
  9. 402BOSSMAN
    402BOSSMAN
  10. RodStRace
    RodStRace
    NICE stuff!
    I will note though that what's the point of Insta if it has a pop up that says, sign with facebook?
    Just an old man shaking his fist at the clouds...
  11. 1934coupe
    1934coupe
    I might have some stuff for you, let me look later tonight or tomorrow. As far as pumps go I went through this stuff with my race car in my avatar. Your best bet is to buy a new one they are rebuildable. And see Alky Digger or Smithberg Racing Boss Fuel Injection.
    Pat
    1biggun likes this.
