Technical Looking for a Special Shock Absorber
Discussion in 'The Hokey Ass Message Board' started by BJR, Jul 29, 2023.
  1. BJR
    BJR
    I need to lower my 49 Buick in the back. To do this I need a shock with loops at both ends, that measures 11" compressed, and 19" or more extended. The longer it can be extended the easier it will be to remove my rear tires. But 19" is the minimum I can live with. I looked at the Monroe chart and the closest I can find is a 32293. It measures 11.97" compressed, 19.66" extended. That doesn't allow me to lower the car, as that is what I have on it now. The measurement is center to center of the loops.
  2. squirrel
    how much fabrication would it take to move the lower mount down an inch? (***uming it would not then be lower than the wheel rim, to avoid scrub line issues)
    BJR and Tow Truck Tom like this.
  3. SS327
    SS327
    My mommy says all shock absorbers are special!
    Tman likes this.
  4. BJR
    BJR
    As you can see I have no room to move the shock mounting points. I am right at the scrub radius, the photo angle Buick rear shock.jpg makes it look worse.
  5. squirrel
    hmmm....
    maybe a few more pictures from different angles, so we can see the whole picture?
    wonder if you could move the top inboard? can't really tell from where we can see it
    BJR likes this.
  6. Clydesdale
    Clydesdale
    How often are you pulling the rear wheels off?
    really too much trouble just to drop the damper off every time?
    I feel like you could be causing yourself a whole lot of work for a fairly limited situation?
    Automotive Stud and BJR like this.
  7. Mr48chev
    You just flat *** are not going to get that much extension with a shock that that has 10 inches of travel.
    Look at front shocks For 60 something to 80 something Chevy C 10 Compressed they are 9.95 and extended they are 15.01 and you have to use two jacks and take the shock loose at the bottom loose at the bottom to get the tire off just as guys had to do back in the day. It helps if you deflate the tire when putting it on or taking it off too, Been there, done that. Screenshot (2040).png
    Automotive Stud, BJR and Bob Lowry like this.
  8. Try Rock Auto for a 1960 VW front shock. The shock has a steel liner inside the rubber bung that can be drilled out and will leave a nice 5/8" hole in the bung. Worked for me.
  9. BJR
    BJR
    I don't think a VW front shock would have enough dampening for the back of my 49 Buick, the weight is way different.
    Here are some more pictures of the installation, I don't see how I can easily move the mounting points.
  10. flatout51
    flatout51
    Just move the lower mount up and keep the current shock. Trim off the mount and get a little more scrub room.
    BJR likes this.
  11. BJR
    BJR
    If I move the lower mount up the shock will bottom out before it hits the bump stops.
  12. flatout51
    flatout51
    Like stated above, you aren't going to be able to find a shock with that much travel. So sit the car on the bump stop, put the shock mounts just far enough apart so the shock doesn't bottom out and plan on removing the shock to get the tire off. It's going to be a game of give and take.
    Clydesdale and BJR like this.
  13. BJR
    BJR
    Yea none of the shocks that size have enough travel. I think the problem is mine are straight up, if the shocks were angled 20 to 25 degrees the rear end would have more travel due to the angle.
  14. goldmountain
    goldmountain
    How are you jacking the car? I jack it up on the frame to let the rear axle drop far enough to remove the tire.
    BJR likes this.
  15. In_The_Pink
    In_The_Pink
    The rear axle would have less vertical travel if the shocks were mounted at an angle less than 90 degrees, so your setup is optimized now.
    The rear coil spring helpers are a bit concerning, though...
    Is the lack of a removable fender (quarter panel) skirt the biggest hinderance to removing the rear wheel/tire currently?
    BJR likes this.
  16. You need to redo the shock mounts. Vertical like that they are less than optimal. I would look at mounting them inboard of the coils with a bit of angle
    BJR likes this.
  17. BJR
    BJR
    Your above statement about the shock angle is wrong. If the shock was angled it would move less then the wheel would move. The way I have it now with the shocks vertical the shock moves about the same up and down as the wheel. I do have removable fender skirts, but still have to let the air out of the tire or unhook the shock to let the rear end drop to get enough room to remove the tire.
  18. Taking things lose on lowered cars to remove tires is traditional.
    rockable, BJR, seb fontana and 2 others like this.
  19. partsdawg
    partsdawg
    from Minnesota
    One of my last '55 Chevy's I had rolled the wheel well openings andmoved the springs and shocks inboard so I could stuff the most tire in the wheel well.
    I had to take the shock loose at the bottom to let the rear end hang down far enough to remove the tire.
    I looked at it as the penalty I had to pay to get the look I wanted.
    X-cpe, BJR and seb fontana like this.
  20. Maybe a circle track approach with cotter pins?
    19Eddy30, BJR and anthony myrick like this.
  21. Why not. Jeeps did that.
    Or a linch pin
    BJR and Tman like this.
  22. 1946caddy
    1946caddy
    from washington
    Have your axles drilled for lug bolts. Allows alot more wiggle room to remove wheel and tire.
    anthony myrick likes this.
  23. 1pickup
    1pickup
    Looks like you could cut the upper mount off, drill a hole, and use a stud type top mount. Might gain you an inch or so in length, if that helps any?
    BJR likes this.
  24. seb fontana
    seb fontana
    from ct
    You want easy? Sheese..
    BJR likes this.
  25. RICH B
    RICH B
    Add a couple ears to the bottom mount so the shock is turned 90 degrees, then move the top mount back also turning it 90 degrees. With the shock angling back and proper locating, you should be able to get it within your parameters.
    anothercarguy and BJR like this.
  26. Kerrynzl
    Kerrynzl
    He's asking for the impossible!
    You cannot get 8"+ travel from a 11" fully compressed shock [when you deduct the eyes from the dimensions]
    It would require a longer shock that is laid over ,
    rotating the shocks 90° and welding "double shear" tabs is the correct/best way [as you suggested]
    another method to "fudge this" is to cut off the top brackets and drill a hole through the frame for an upper stud mount [this might gain 3/4"]
    But if fabrication is needed..............do it properly
    @BJR Use a KYB #343164 shock
    This is 12.91" compressed and 21.57" extended.
    Mount the upper eye 6.76" offset from perpendicular and it will net 11" compressed and 20.48" extended
    The eyes are 10mm x 41mm upper and lower
    BJR likes this.
  27. BJR
    BJR
    Thanks everyone for the great suggestions. Looks like I have some welding in my future.
