Hot Rods Looking for a sway bar
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Jul 9, 2016.
  1. HOTRODPRIMER
    HOTRODPRIMER
    My pal Dave,the owner of the 34-32 confused pickup,called me tonight asking me if I knew of a manufacture of a bolt on sway bar.
    In the test drive around the block the truck experienced some body roll and he cut up the right rear tire.
    The truck has a triangular 4 bar and coil over shocks,he's a little bummed out and really needs to find a bolt on sway bar if it exist,he sure doesn't want to start grinding and welding on all the fresh paint.
    I would appreciate any leads. HRP
  2. willys36
    willys36
    Find an old 70's Ford Courier pickup. Their front sway bar is perfect for most pre-war cars. I put one on the rear of my '36 Willys & my '36 Pontiac Sedan. Bar is straight with splayed ends @ about 30deg but they can be bend in a press to straight back if necessary.
    HOTRODPRIMER likes this.
  3. FrankenRodz
    FrankenRodz
  4. HOTRODPRIMER
    HOTRODPRIMER
    Thanks for the lead and I'll p*** it along but Dave is under the gun to finish the interior and correct this problem by next Saturday. HRP
  5. DDDenny
  6. Montana1
    Montana1
    I have the exact same rear suspension on a 9", so I used the anti-sway bar off a mid 80's F-250. I harvested the bar, axle mounts and frame mounts for only $25.
    I turned the frame mounts to bolt right on the '32 frame rails and then used some replacement short links with poly bushings from Auto-Zone. It fits perfect without modification.
    It used to change lanes when I stabbed it, but now it goes straight as an arrow. Handles like a go-kart around curves.
  7. D.N.D.
    D.N.D.
    I bought a Ford rear sway bar for my 78' Ranchero and it corners like a go-kart , along with the 50 series TA radials
  8. okiedokie
    okiedokie
    from Ok
    I have never used a four bar, but isn't a panhard bar required?
  9. Montana1
    Montana1
    If it is a parallel 4-bar, yes. Triangular 4-bar, no.
  10. HOTRODPRIMER
    HOTRODPRIMER
    My black sedan has a torsion bar set up that I purchased from TCI years ago and it too handles like a slot car. HRP
  11. HOTRODPRIMER
    HOTRODPRIMER
    Thanks for all the hints and advice,the urgency is a non issue now,Dave found water in the oil last night so taking the car to Kentucky ain't gonna happen this weekend. HRP
  12. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    Also early 80s T bird has a good one. Rear bar that is.
  13. I have been to a gay bar, a lesbian bar even a cowboy bar but I have never even heard of a sway bar. That's just weird man. :confused: o_O:rolleyes:
  14. HOTRODPRIMER
    HOTRODPRIMER
    Damn Beeno,you get stranger every day!:rolleyes:
    I'm certain you have bellied up to the bar and frequented many a biker bar but what about a crow bar,piano bar or a sissy bar? HRP
  15. Atwater Mike
    Atwater Mike
    ...Or a Candy bar? Suh-weeeet...
  16. hotroddon
    hotroddon
    A sway bar is another name for a Swisher Bar, and that is code for Gay Bar ~ If you're into that sort of thing.
    Now as for an Anti Sway Bar ~ I would go with TCI's set up.
  17. Damn Don,
    I have been away from home long. :D
    @HOTRODPRIMER My favorite is a salad bar. :D
  18. HOTRODPRIMER
    HOTRODPRIMER
    Oh yeah,I didn't even think of the one and only Candy Bar! hubba,hubba. HRP
    edited photo
  19. hotroddon
    hotroddon
    Road Eyes
  20. dadz34
    dadz34
    from Sanger, TX
